4948 Switch Commands are Slow
mramirez-t
I have a 4948 that when running commands via SSH, is EXTREMELY SLOW.  To the point that I write commands in notepad and copy them to the switch when I'm putty'ing in.  When running anything on the switch, I can type like normal, but the command only appears on the display output slowly, character by character instead of display output showing normal as I type a command.
I've tried pinging the switch, no problem.  Below is ping results when I'm pinging the switch from 4 states away.
Pinging 10.11.128.132 with 32 bytes of data:
Reply from 10.11.128.132: bytes=32 time=31ms TTL=250
Reply from 10.11.128.132: bytes=32 time=39ms TTL=250
Also, none of the servers connected to the switch are showing any problems of network performance drag, so it's isolated to running commands.  Below is running-config.  Not sure what to look for here.  Any help's appreciated.
login as: mradmin
Using keyboard-interactive authentication.
Password:
HQN-C4948#sh run
Building configuration...
Current configuration : 5456 bytes
! Last configuration change at 09:34:03 UTC Thu Apr 20 2017 by XXXadmin
version 15.2
no service pad
service compress-config
hostname HQN-C4948
boot-start-marker
boot system flash bootflash:cat4500e-lanbasek9-mz.152-3.E.bin
boot-end-marker
vrf definition mgmtVrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
username admin privilege 15 secret 5 $1$V7sT$ExuHj0nic0TuyU8Az9q9K1
aaa new-model
aaa group server radius XXXRadius
 server-private 10.5.144.114 key XXXXXXXXX
aaa authentication login default local group XXXRadius enable
aaa authentication enable default line
aaa authorization console
aaa authorization exec default local group XXXRadius
aaa session-id common
vtp mode transparent
no ip routing
ip domain-name XXX.org
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2,40,44,46-47,73-77,79,86,88-89,91,104,110-117,128,1000
interface Port-channel52
 description Uplink to 4500 Internal
 switchport
 switchport mode trunk
interface FastEthernet1
 vrf forwarding mgmtVrf
 ip address 10.11.128.132 255.255.255.0
 no ip redirects
 no ip route-cache
 speed auto
 duplex auto
interface GigabitEthernet1/1
 shutdown
interface GigabitEthernet1/2
 shutdown
interface GigabitEthernet1/3
 switchport access vlan 47
 switchport mode access
interface GigabitEthernet1/4
 switchport access vlan 77
interface GigabitEthernet1/5
 switchport access vlan 75
interface GigabitEthernet1/6
interface GigabitEthernet1/7
 shutdown
interface GigabitEthernet1/8
interface GigabitEthernet1/9
 shutdown
interface GigabitEthernet1/10
 shutdown
interface GigabitEthernet1/11
 switchport access vlan 91
interface GigabitEthernet1/12
 description Test-Temp
 shutdown
interface GigabitEthernet1/13
 switchport access vlan 44
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
 shutdown
interface GigabitEthernet1/17
 shutdown
interface GigabitEthernet1/18
 shutdown
interface GigabitEthernet1/19
 shutdown
interface GigabitEthernet1/20
 shutdown
interface GigabitEthernet1/21
 shutdown
interface GigabitEthernet1/22
 shutdown
interface GigabitEthernet1/23
 shutdown
interface GigabitEthernet1/24
 shutdown
interface GigabitEthernet1/25
 shutdown
interface GigabitEthernet1/26
 shutdown
interface GigabitEthernet1/27
 shutdown
interface GigabitEthernet1/28
 shutdown
interface GigabitEthernet1/29
 shutdown
interface GigabitEthernet1/30
 shutdown
interface GigabitEthernet1/31
 shutdown
interface GigabitEthernet1/32
 shutdown
interface GigabitEthernet1/33
 shutdown
interface GigabitEthernet1/34
 shutdown
interface GigabitEthernet1/35
 shutdown
interface GigabitEthernet1/36
 shutdown
interface GigabitEthernet1/37
 switchport access vlan 74
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
 shutdown
interface GigabitEthernet1/43
 shutdown
interface GigabitEthernet1/44
 shutdown
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
 shutdown
interface GigabitEthernet1/48
 shutdown
interface TenGigabitEthernet1/49
 shutdown
interface TenGigabitEthernet1/50
 shutdown
interface TenGigabitEthernet1/51
 channel-group 52 mode active
interface TenGigabitEthernet1/52
interface Vlan1
 no ip address
 no ip route-cache
ip default-gateway 10.11.128.1
no ip http server
no ip http secure-server
ip forward-protocol nd
snmp-server community XXX1999 RO
snmp-server community XXXCORE RO
radius-server host 10.5.144.114 key XXXXXXXX
line con 0
 stopbits 1
line vty 0 4
 logging synchronous
 transport input ssh
end
HQN-C4948#
Reza Sharifi
I have seen the same type of issue with Nexus when SNMP is enabled.  Can you disable or remove SNMP and test again?
I disabled SNMP.  Unfortunately it didn't do anything.
