Adding a wic 4esw card to cisco 1721
randy kruen
Hi. I have a Cisco 1721 that is facing my provider on fe0, dhcp address. It is feeding 3 subnets downstream to another location via serial0. I am adding a wic 4esw card to it, I have configured the card to give dhcp addresses in the range of 192.168.1.x, and that is working. I am missing something though as I cannot yet connect to the internet through fe0 when connected to any fe1-4 ports. Can someone tell me what I have missed? config below, and thanks very much for your time!
Randy
ip cef
no ip dhcp use vrf connected
ip dhcp pool vlan1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 24.153.23.66 24.153.22.67
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0 (faces my provider)
ip address dhcp
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
interface FastEthernet1 (fe1 to 4 are the new ports on the wic 4esw card)
duplex full
speed 100
interface FastEthernet2
duplex full
speed 100
interface FastEthernet3
duplex full
speed 100
interface FastEthernet4
duplex full
speed 100
interface Serial0 (faces downstream to feeds 3 subnets)
ip address 192.168.2.2 255.255.255.0
ip nat inside
service-module t1 clock source internal
service-module t1 timeslots 1-24
interface Vlan1
vlan-id dot1q 2
exit-vlan-config
ip forward-protocol nd
ip route 192.168.3.0 255.255.255.0 192.168.2.1
ip route 192.168.4.0 255.255.255.0 192.168.2.1
ip route 192.168.5.0 255.255.255.0 192.168.2.1
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
Mark Malone
Hi try ip nat inside under the vlan 1 interface , there layer 2 ports that are assigned to the vlan now that you have assigned a switch module to the router , so there layer 3 interface which is the vlan 1 interface needs to have nat inside on it so they can all break out to the internet
Mark Malone
Thanks very much for your reply. I added that to my config, will have to drive about 30km though to physically verify. will do though and post results!
Randy
Hi Mark. Thanks again, I was on site today and tested the new config, works mint. Much appreciated!
Randy
No problem glad it worked
