08-20-2020 04:32 PM - edited 08-21-2020 09:09 PM
hi
The situation is
vlan 200
SW1 that got Vlan 200 i got Port 45 as Trunk...
the configuration is
switch port mode access vlan 200
switch port mode trunk
ip dhcp snooping trust
the 4G router gateway is 10.0.300.1
Senaerio1
I connected the 4g router to the switch
I go to the pc and i give it 10.0.300.52 and default gateway 10.0.300.1 but no internet!
senerio 2
I connected a Managed TPLink router to the switchport
I connected the 4g router to the Managed TPLink
I go to the pc and i give it 10.0.300.52 and default gateway 10.0.300.1 but internet work!
Note : DHCP disabled on the 4G Router
How can i Solve this problem.. i want to connect the 4g to the switch and get internet from the Computer side within the vlan 200 only
08-21-2020 07:40 PM
08-21-2020 09:04 PM - edited 08-21-2020 09:10 PM
I want the 4G Router to distrbute internet inside vlan 200 only.. I modified my Question
so do i make port 45 access port or Trunk Port ?
and what are the configs for that port?
08-21-2020 09:10 PM
08-21-2020 09:12 PM - edited 08-21-2020 09:18 PM
thats what i did but it didnt get internet from the computer side,, or u mean i have to do it in same code order?
08-21-2020 09:13 PM - edited 08-22-2020 01:09 PM
