6500 basic questions
gautamzone
Level 6
Level 6
Hi friends,
I just wanted to get answers to a few basic questions:
1. In 6509-E switch, here is the relevent output of show file systems command:
------------------ show file systems ------------------
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw *
512024576 470073344 disk rw sup-bootdisk: sup-bootflash:
I see that both sup-bootdisk: and sup-bootflash: are mentioned. Does it mean that sup-bootdisk: is an alias for sup-bootflash: ?
So, if i say either boot system sup-bootflash or boot system sup-bootdisk, they both mean the same?
2. For 12.2SXF10, I believe that there are two IP Services images viz.
a. s72033-ipservices_wan-mz.122-18.SXF10.bin
b. : s72033-ipservicesk9-mz.122-18.SXF10.bin
What is the difference between these two images? Which one is relevant for 6509-E switch with Sup 720-3B currently running s72033-ipservicesk9-mz.122-18.SXF5.bin ?
Thanks a lot
Gautam
sgelli
Level 4
Level 4
Starting 12.2(18)SXF code, a compact flash in place of bootflash is being supported. So, sup-bootdisk is a replacement for sup-bootflash.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/sup720.html#wp1053703
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_17277.htm#wp50076
K9 is for 3DES (Triple encryption software). The main difference is that the first image does not have 3 DES and the 2nd one does.
arburt
Hi Gautam,
1.
sup-bootflash: - 64-mb bootflash device in Sup720
sup-bootdisk: - the 512-mb CF card
2.
unique features w/ k9 is SSH.
if you are using SSH before(sxf5), stick it k9.
arburt
