6500 High CPU Utilization
engineerangelo
We have a problem with a 6506-E which is having a high CPU utilization.
Here's the output from the show proc cpu:
6506_A#sh proc cpu
CPU utilization for five seconds: 79%; one minute: 81%; five minutes: 78%
PID 5Sec 1Min 5Min Process
1 0.1% 1.2% 1.4% kernel
3 0.0% 0.0% 0.0% qdelogger
4 0.0% 0.0% 0.0% devc-pty
5 0.0% 0.0% 0.0% devc-mistral.proc
6 0.0% 0.0% 0.0% pipe
7 0.0% 0.0% 0.0% dumper.proc
4104 0.0% 0.0% 0.0% bflash_driver.proc
12297 0.0% 0.0% 0.0% pcmcia_driver.proc
12298 0.0% 0.0% 0.0% mqueue
12299 0.0% 0.0% 0.0% flashfs_hes.proc
12300 0.0% 0.0% 0.0% dfs_bootdisk.proc
12301 0.0% 0.0% 0.0% ldcache.proc
12302 0.0% 0.0% 0.0% watchdog.proc
12303 0.0% 0.0% 0.0% syslogd.proc
12304 0.0% 0.0% 0.0% name_svr.proc
12305 0.0% 0.1% 0.1% wdsysmon.proc
12306 0.0% 0.0% 0.0% sysmgr.proc
16386 0.0% 0.0% 0.0% chkptd.proc
16403 0.0% 0.0% 0.0% sysmgr.proc
16404 0.0% 0.0% 0.0% syslog_dev.proc
16405 0.0% 0.0% 0.0% itrace_exec.proc
--More-- PID 5Sec 1Min 5Min Process
16406 0.0% 0.0% 0.0% packet.proc
16407 0.0% 0.0% 0.0% installer.proc
16408 75.3% 75.6% 72.7% ios-base
16409 0.0% 0.0% 0.0% fh_fd_rf.proc
16410 0.0% 0.0% 0.0% fh_fd_oir.proc
16411 0.0% 0.0% 0.0% fh_metric_dir.proc
16412 0.0% 0.0% 0.0% fh_fd_snmp.proc
16413 0.0% 0.0% 0.0% fh_fd_none.proc
16414 0.0% 0.0% 0.0% fh_fd_intf.proc
16415 0.0% 0.0% 0.0% fh_fd_counter.proc
16416 0.0% 0.0% 0.0% fh_fd_gold.proc
16417 0.0% 0.0% 0.0% fh_fd_cli.proc
16418 0.0% 0.0% 0.0% fh_fd_timer.proc
16419 0.0% 0.0% 0.0% fh_fd_ioswd.proc
16420 0.0% 0.0% 0.0% fh_server.proc
16421 0.0% 0.0% 0.0% fh_policy_dir.proc
16422 0.0% 0.0% 0.0% ipfs_daemon.proc
16423 0.1% 0.4% 0.4% raw_ip.proc
16424 0.0% 0.0% 0.0% inetd.proc
16425 0.0% 0.1% 0.1% tcp.proc
16426 1.6% 1.7% 1.4% udp.proc
16427 0.6% 0.7% 0.7% iprouting.iosproc
16428 0.1% 0.2% 0.1% cdp2.iosproc
6506_A#
We searched this output in the Output Interpreter and it indicated that it could be an IOS bug. Its IOS is 12.2(18)SXF11.
Hope someone has an idea on this.
Thanks.
Giuseppe Larosa
Hello Angelo,
there is a single process taking most of cpu resources:
you should use Bug toolkit tool.
I tried a search for C6500, 12.2 18 SXF11 release using high cpu as search keyword:
I've found the following:
CSCsr12976 Bug Details
High CPU in ION ios-base process
Symptom:
CPU climbs high over a period of time until switch crashes to recover.This is due to "show run" command being run on the switch periodically which hold memory regions and does not release them which in turn contributes to high cpu.
Workaround:
(1) Stop running the "show run" command to prevent the CPU climb.
(2) Reload the switch to recover memory and CPU.
you need to upgrade to something newer
Hope to help
Giuseppe
