6500 IOS QoS for Multicast
jradke
Question Summary:
How do I set the p-bit (COS value) for multicast traffic ingressing on an interface?
Additional details:
  1. Although I have had success matching all IP traffic ingressing from the encoder/streamer (multicast source) I want to match only multicast traffic.
  2. I see no obvious reason why my attempts with ACL's for multicast are failing to match. Help!
  3. I verified failing or work by output of policy-map information, wireshark from port mirror, and remote client receiving the multicast.
Traffic Type (Multicast):
Source IP: 10.0.0.1
Source Port: 1025
Destination IP: 239.100.0.5
Destination Port: 8208
Destination MAC: 01:00:5e:64:00:05
Here is my configuration:
class-map IPTV
match access-group <ATTEMPT X>
policy-map MARK_INBOUND_IPTV
  class IPTV
   set dscp cs4
interface GigabitEthernet3/9
service-policy input MARK_INBOUND_IPTV
Individually attempted the following ACL's for the match statement<ATTEMPT X>:
FAIL:
  1. access-list 81 permit 224.0.0.0 15.255.255.255
  2. access-list 4 permit 239.100.0.5
  3. access-list 700 permit 0100.5e13.05b8 0000.00ff.ffff
  4. access-list 700 permit 0100.5e00.0000 0000.00ff.ffff
SUCCESS: (inadequate because it is all IP traffic not just multicast)
  1. access-list 7 permit any
Command output from Fails:
sho policy-map int g3/9 detailed
GigabitEthernet3/9
   Service-policy input: MARK_INBOUND_IPTV
    class-map: IPTV (match-all)
      Match: access-group 4
      set dscp 32:
      Earl in slot 5 :
        Traffic:        Total bytes          30-s bytes          peak bytes       5-min avg bps            peak bps
        Offered                   0                   0                   0                   0                   0
        Agg-fwd                   0                   0                   0                   0                   0
        Exceed                    0                   0                   0                   0                   0
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match: any
        0 packets, 0 bytes
        30 second rate 0 bps
sho policy-map int g3/9 input
GigabitEthernet3/9
      set dscp 32:
      Earl in slot 5 :
        0 bytes
        30 second offered rate 0 bps
        aggregate-forwarded 0 bytes
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
jradke
I found that matching on the destination port number works as well:
access-list 104 permit udp any any eq 8208
GigabitEthernet3/9
      Match: access-group 104
      set dscp 32:
      Earl in slot 5 :
        64144752 bytes
        30 second offered rate 3980472 bps
        aggregate-forwarded 64144752 bytes
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
I'd really like to match on all multicast though. The destination IP or MAC makes the most sense but they fail.
Success! Using this extended list to specify the multicast works as needed:
access-list 104 permit udp any 224.0.0.0 15.255.255.255
different from the ACL I found in a posting earlier which doesn't work:
