6500 or 4500, VSS
carl_townshend
Hi all
Am I right in saying the 4500 now supports VSS ?
We need some new core switches for our datacentre but the 6509 may be overkill, possibly looking at 4507
what would be the rough percentage diff in price for these ?
Is the 4507 with Supervisor 8E powerful switch, we have the sup 720's in our 6509 at present, is it as poweful as them ?
cheers
InayathUlla Sharieff
Carl ,
Yes you are right 4500 supports VSS
Ref: https://supportforums.cisco.com/docs/DOC-29472
Not sure about the price you might need to google it or check with any of your reseller.
this is the datasheet please refer the same and you would get an idea:
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_models_comparison.html#~tab-e
Inayath
**Please rate if this info is helpfull.
Leo Laohoo
Correct.
Carl,
What are clients are you planning to connect?  If you're going to say VMware or ESX "grade" servers, aka high-speed, hit-less servers, then 6500 or 4500 or 6800 will not be sufficient.
Think bigger, Nexus 7K, 6K, 5K & 2K is your solution.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
"Ballpark", 4500 approach is probably going to be 1/3 to 1/2 cost of 6500 approach.
Comparing which is more (powerful depends very much on chassis, line card and supervisor choices.  With the 6500s, DFCs are important too.
A "powerful" comparision might also include features (6500 tends to be feature richer).
