6500 QOS, Please help
jvankirk
I am looking for help on what the QOS configuration should look like for a 6500 that sits in the core. I know there are many resources for me to read (and I intend to read them), but I'm in a huge crunch to get a friends connection up ASAP. All help is greatly appreciated. Below is the relevant information:
vid_encoder--4948-->GI1/2 6500 GI1/21--MOE<--3750--vid_encoder
QOS Config:
mls qos
mls netflow interface
no mls flow ip
no mls flow ipv6
mls cef error action reset
class-map match-any ALL-out
  match ip dscp default  cs1  cs2  cs3  cs4  cs5  cs6  cs7
class-map match-all ALL-in
  match access-group name ALL
policy-map 4.0-in
  class ALL-in
   police 4000000 250000    conform-action transmit     exceed-action drop
policy-map 1.0-in
  class ALL-in
   police 1000000 250000    conform-action transmit     exceed-action drop
policy-map 4.0-out
  class ALL-out
policy-map 1.0-out
  class ALL-out
interface GigabitEthernet1/2
switchport
switchport trunk allowed vlan 1-999
switchport mode trunk
mls qos trust dscp
interface GigabitEthernet1/21
switchport
switchport access vlan 500
switchport mode access
mls qos trust extend
mls qos trust cos
sh inv
NAME: "WS-C6509-E", DESCR: "Cisco Systems Catalyst 6500 9-slotChassis System"
PID: WS-C6509-E
NAME: "WS-C6K-VTT-E 1", DESCR: "VTT-E FRU 1"
PID: WS-C6K-VTT-E
NAME: "WS-C6K-VTT-E 2", DESCR: "VTT-E FRU 2"
PID: WS-C6K-VTT-E
NAME: "WS-C6K-VTT-E 3", DESCR: "VTT-E FRU 3"
PID: WS-C6K-VTT-E
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
PID: CLK-7600
NAME: "1", DESCR: "WS-X6724-SFP CEF720 24 port 1000mb SFP Rev. 2.3"
PID: WS-X6724-SFP
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 1", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 2.0"
PID: WS-F6700-CFC
NAME: "3", DESCR: "WS-X6348-RJ-45 48 port 10/100 mb RJ45 Rev. 1.5"
PID: WS-X6348-RJ-45
NAME: "5", DESCR: "WS-SUP720-3BXL 2 ports Supervisor Engine 720 Rev. 5.11"
PID: WS-SUP720-3BXL
NAME: "msfc sub-module of 5", DESCR: "WS-SUP720 MSFC3 Daughterboard Rev. 5.0"
PID: WS-SUP720
NAME: "WS-F6K-PFC3BXL Policy Feature Card 3 sub-module of 5", DESCR: "WS-F6K-PFC3BXL Policy Feature Card 3 Rev. 1.11"
PID: WS-F6K-PFC3BXL
NAME: "6", DESCR: "WS-SUP720-3BXL 2 ports Supervisor Engine 720 Rev. 4.3"
PID: WS-SUP720-3BXL
NAME: "msfc sub-module of 6", DESCR: "WS-SUP720 MSFC3 Daughterboard Rev. 2.3"
PID: WS-SUP720
NAME: "WS-F6K-PFC3BXL Policy Feature Card 3 sub-module of 6", DESCR: "WS-F6K-PFC3BXL Policy Feature Card 3 Rev. 1.6"
PID: WS-F6K-PFC3BXL
sh ver
<snip>
Compiled Fri 25-Apr-08 11:35 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
6500 uptime is 17 weeks, 3 days, 20 hours, 49 minutes
<snip>
System image file is "disk0:/s72033-adventerprisek9_wan-vz.122-33.SXH2a.bin"
<snip>
cisco WS-C6509-E (R7000) processor (revision 1.4) with 1040384K/8192K bytes of memory.
Processor board ID SMG1133N69X
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from power-on
39 Virtual Ethernet interfaces
48 FastEthernet interfaces
28 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed image. To install please use the "install file" command
0 Replies 0
