6500 qos sup720 pfc3b ws-x6748-ge-tx
Hi All
need little help with understanding qos on 6509. i have two layer circuits coming from dc into campus which terminate onto 6509, i need to know how to configure qos... whether to configure svi or subinterface? ....current qos plocy has voice prioritzed amd policed and wee have parent and child qos statement..any help is highly appreciated. thanks
Philip D'Ath
Is the layer 2 circuits size the same as the access size?  For example, you have a 1Gb/s access, and the circuit size is also 1Gb/s?  If so you don't need a child policy.  If not, say the circuit size is 512Mb/s then you would need to consider a child policy.
Is this layer 2 circuit a trunk with many VLANs on it, a single VLAN, or terminating on a layer 3 interface on the 6509?
Hi Philip
we have single pipe but two evc going into two different datacenter, each is one gig but both terminate on same port (1gig) on campus end i would be spliting bandwidth and assigning 500 meg to each layer 3 subinterface. correct model is ws-x6724-sfp. can layer 3 subinterfaces be created on 6724 model? and would be able to apply qos with queuing, shapling and policing. thanks
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I recall shaping is not supported on a 6724.  Queuing is, but its specific to the card's hardware.  Don't recall whether policing is supported on egress, it should be supported on ingress.
InayathUlla Sharieff
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/white_paper_c11_538840.html
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/24055-173.html
Inayath
