How to clear arp in 2960s ?
ilya_tyapugin
Hello, how to clear incomplete arp in 2960s ?
I waited for more than 4 hours, but mac address is still in the mac table.
DMZ_SWITCH#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.8.26            -   64a0.e79c.5341  ARPA   Vlan46
Internet  192.168.8.240           0   Incomplete      ARPA
Internet  192.168.8.252           7   58ac.78b4.1b53  ARPA   Vlan46
Internet  192.168.8.253          19   58ac.78b4.1e63  ARPA   Vlan46
Internet  192.168.8.254           5   0000.0c9f.f02e  ARPA   Vlan46
DMZ_SWITCH#clear arp
DMZ_SWITCH#
DMZ_SWITCH#sh arp
Internet  192.168.8.254           0   0000.0c9f.f02e  ARPA   Vlan46
DMZ_SWITCH#clear ip arp 192.168.8.240
DMZ_SWITCH#sh arp
DMZ_SWITCH#clear arp-cache
DMZ_SWITCH#sh arp
 WS-C2960S-24PS-L   12.2(55)SE3           C2960S-UNIVERSALK9-M
What the problem could be?
15 Replies 15
Mark Malone
what is that ip address 192.168.8.240 ? where is it connected do you have the mac address , its incomplete so there could be a nic or cable issue on the actual device ,, trace the mac shut the port , clear the mac table for the specific mac then clear the arp for it
Yes it is 192.168.8.240, no ip 8.240 in the network.
Before there was core switch  with ip address of 192.168.8.240, than I changed 8.240 to 8.253 and apply hsrp ip 8.254 to this vlan.
Also we have 3750, on 3750 clear arp worked fine, but on 2960s it is still in arp table.
Can not trace or can not be listed 8.240 in mac address table of the core switch.
Topology network pretty simple , 2Xcore switches (nexus 9300) and VPC access swithes. And the problem has only one 2960s.
Could be bug?
Sounds to me like something on the network is still trying to communicate with 192.168.8.240.
If anything is trying to communicate with this address,  the arp will be sent but as there is no response, the MAC address will be listed as 'incomplete' in the ARP cache.
I would check your hosts to see if you have any that still have 8.240 as their default gateway, perhaps a Non DHCP host still has a static configuration.
If you were to login to your switch and ping any IP address that was not in use, you would see an 'incomplete' for this entry in the ARP cache because there was no reply.
... and presumably it is being polled regularly, keeping the entry alive.  If you have no ideas which static entry is causing it, you could put wireshark on a port on that vlan and capture for a short while (i.e. 10 minutes ?) and check through the frames for that request.
Yes you are right, cisco switch itself pooling arp request for 192.168.8.240, Now how to understand Why it is doing this, the only configuration is ip defaul-gateway 192.168.8.254
Very strange behavior , how it could be ?
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan46
 ip address 192.168.8.26 255.255.255.0
ip default-gateway 192.168.8.254
ip http server
ip http secure-server
ip sla enable reaction-alerts
logging 192.168.5.9
So , default gateway is 192.168.8.254 (HSRP) real is 8.252 , now I ping
ping 192.168.5.41
Sending 5, 100-byte ICMP Echos to 192.168.5.41, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/6 ms
DMZ_SWITCH#ping 192.168.5.9
Sending 5, 100-byte ICMP Echos to 192.168.5.9, timeout is 2 seconds:
Success rate is 0 percent (0/5)
DMZ_SWITCH#
DMZ_SWITCH#
DMZ_SWITCH#trace
DMZ_SWITCH#traceroute 192.168.5.41
Tracing the route to 192.168.5.41
  1 192.168.8.252 0 msec 0 msec 0 msec
  2  *  *  *
  3  *  *  *
DMZ_SWITCH#
DMZ_SWITCH#traceroute 192.168.5.9
Tracing the route to 192.168.5.9
  1  *  *  *
  2  *  *  *
  3  *  *  *
It is looks like it wants to use 8.240 as a gateway for 5.9 only , but for 5.41 it is using correct 8.254
You did not get an ICMP reply for 192.168.5.9 when you tried to ping it so I would expect a traceroute to go nowhere as it uses the ICMP protocol.
I see no issues with what you posted above.
The issue is likely not with your switch, there is probably a host somewhere on the network which is using the 192.168.8.240 address for something, hence why the ARP entry is always there.
Do you have any issues or just questioning why the Incomplete ARP entry is there for 8.240?
I have an issue , on 192.168.5.9 we have monitoring program, prtg, and it can not monitor my switch - 192.168.8.26 , no connection between them .
And why when I ping or trace 192.168.5.9 it is not using default gaytway? When I ping or trace 192.168.5.41 it is using correct gateway ?
Can you post results of the following from that switch:
#show ip route 192.168.5.9
Possibly also post the full config of the switch.
no ip routing jast ip default-gateway
DMZ_SWITCH# sh ip route
% Invalid input detected at '^' marker.
Ahhh ok well can you confirm the 192.168.5.9 address has the correct default gateway set?
What L3 device on your network is hosting the default gateway for the 192.168.5.x subnet?
Yes I confirm 192.168.5.9 uses correct gateway, L3 on core nexus switches for all vlans 192.168.8.x and 192.168.5.x
I Use wareshark and 192.168.8.26 ask arp for 192.168.8.240 , now I confused Why ?
And I found another cisco swich is asking arp for 192.168.8.240 , look at this another cisco switch
19_Floor#sh ip route
Default gateway is 192.168.8.254
Host               Gateway           Last Use    Total Uses  Interface
192.168.5.16       192.168.8.240         0:00          6345  Vlan46
19_Floor#sh arp
Internet  192.168.8.13            -   001e.135b.36c1  ARPA   Vlan46
Internet  192.168.8.18            0   001b.2b80.d2c3  ARPA   Vlan46
Internet  192.168.8.31           13   6c99.89cf.70c1  ARPA   Vlan46
Internet  192.168.8.254         193   0000.0c9f.f02e  ARPA   Vlan46
19_Floor#sh run | include 192.168.8.240
19_Floor#
interface Vlan1
 no ip address
interface Vlan46
 ip address 192.168.8.13 255.255.255.0
ip classless
ip http server
Do you have any idea from where this switch take this configuration?
The only configuration are Ip defaul-gateway 192.168.8.254
nothing
Looks like it is IP Redirect issue
have you tried clearing the ip from the arp table at layer 3 , clear ip arp 192.168.8.240 , if its still coming back after that something might be using it
you could setup advanced ip scanner and see if its live somewhere , its freeware
