6500 sup 720 IOS upgrade question
Jason Dance
Hi.
I read this document about upgrading the IOS on a 6500 with redundant Sup720-3Bs. http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/71585-cat6k-red-supeng-swimg-upg.html. ; I am going from IOS 12.2(33)SXH to 12.2(33)SXJ10.
When I got to the part after the standby comes up on the new version and its time to issue "redundancy force-switchover", what sort of network disruption should I be expecting as I switch to the newly upgraded standby Sup?
Jason
Iulian Vaideanu
Level 4
Level 4
There is a note at the end of step 13 in that document, stating that "In middle of the software upgrade procedure, the operational redundancy mode is RPR. This is evident from the show redundancy states command output shown in step 12. In RPR redundancy, during switchover, all switching modules are powered on again. So there is be a few minutes of downtime."
Iulian Vaideanu
Level 4
Level 4
Thanks Iulian.  This indeed happened when I performed this upgrade over the weekend.
You sure took a while to go for it :)...
Priorities, what can I say? :)
