6500-VSS but not VSS
Hello
Just a Quick question regarding VSS.
Can the VSS Pair act as separate redundant switches. Or is that it the Supervisor is built to act in VSS Mode only.
I have two 6506-E with VS-S720-10G-3C. I want them to act as separate switches like if there is no VSS capability.
I will add the VSS configuration later on.
Zeeshan Sanaullah)
Hello Zeeshan,
it is possible that from a licesing point of view the tool makes distinction.
However, that is an IOS image
I have a recent switch with
sh ver | inc image
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-33.SXI2a.bin"
for example.
The file name is that of a legitimate IOS image
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Zeeshan,
yes you can do this.
But you will need to take care during the migration process to VSS.
see
http://www.cisco.com/en/US/partner/products/ps9336/products_tech_note09186a0080a7c74c.shtml
or
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c74c.shtml
these are still Sup720 supervisors after all with the added VSS features.
hope to help
Giuseppe
Thanks ...
One more thing
Im using Dynamic Config tool which is giving me a some error that says
Errors 1. When only ordering the primary supervisor, please select one of the following software: SV33IBL-12233SXH/SXI, SV33IBK9L-12233SXH/SXI, SV33IBN-12233SXH/SXI, or SV33IBK9N-12233SXH/SXI.
I have selected " SV33AIK9M-12233SXI (s72033-advipservicesk9_wan-vz.122-33.SXI.bin)"
It looks like some ordering math.
But can i use " SV33AIK9M-12233SXI (s72033-advipservicesk9_wan-vz.122-33.SXI.bin)" with one supervisor
Hello Zeeshan,
sh ver | inc image
for example.
Hope to help
Giuseppe
What is the Default DRAM on Switch Processor and MSFC on the VS-S720-10G-3C supervisor
Thanks in Advance
Zeeshan
Hello Zeeshan,
this can be seen on the datasheet
• Cisco Virtual Switching Supervisor Engine 720 3C supports 1 GB of DRAM for the route processor and 1 GB for the switch processor
• Cisco Virtual Switching Supervisor Engine 720 3CXL supports 1 GB DRAM for the route processor and 1 GB DRAM for the switch processor
• 1 GB compact flash for switch processor and 64 MB of boot flash for route processor
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/product_data_sheet0900aecd806ed759.html
Hope to help
Giuseppe
