6506E Rebooted Unexpectedly
william.briere
Here is a message in the log after one of our redundant 6506E's just rebooted unexpectedly. Anything look like a smoking gun to any of you?
Your help and comments are appreciated.
william.briere
Would help to add the portion of the log...
00:00:11: BaseBoard Index:147
00:00:11: DaughterBoard Index:208 (Centralized Forwarding Card)
00:00:11: Gemini Rev#: 3
Firmware compiled 20-Feb-07 15:11 by integ Build [100]
00:00:13: %SYS-CFC1-5-RESTART: System restarted --
IOS (tm) c6lc2 Software (c6lc2-SP-VM), Version 12.2(18)SXF9, RELEASE SOFTWARE (f
c1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 17-May-07 00:54 by kellythw
*Nov 30 00:00:02.340: CFC1: Currently running ROMMON from S (Gold) region
00:03:41: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
00:03:58: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
00:04:05: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
william.briere
where would I find this file? Is there a show command for it?
dir sup-bootflash:
You can copy the file via TFTP or FTP to your PC.
jerry
Leo Laohoo
Look for a crashinfo file and post it.
