6509 DHCP problem
wilsonyong
6509 DHCP config:
ip dhcp pool xinxizhongxin
network 172.21.0.0 255.255.0.0
default-router 172.21.0.1
netbios-name-server 137.10.0.71
dns-server 202.96.104.15
interface Vlan6
description XinXiZhongXin
ip address 172.21.0.2 255.255.0.0
ip access-group control_vlan6 out
no ip redirects
no logging event link-status
standby 6 ip 172.21.0.1
standby 6 priority 110
standby 6 preempt
client can assign IP addresses。
6509 config:
network 10.46.138.0 255.255.255.128
default-router 10.46.138.126
interface Vlan6
ip address 10.46.138.124 255.255.255.128
no ip redirects
standby 2 ip 10.46.138.126
standby 2 priority 110
standby 2 preempt
client not assign IP addresses .
debug ip dhcp packet
debug ip dhcp even
DHCPD: requested address 169.254.83.239 is not on subnet 10.46.138.0.
DHCPD: address pool xinxizhongxin is empty.
Yudong Wu
Level 7
Level 7
some suggestions:
1. make sure spanning-tree portfast is enabled on access port.
2. try release/renew IP from client PC.
3. on switch, check if there is conflict by "sh ip dhcp conflict".
4. then try "clear ip dhcp conflict"
