6509 and unrouted VLAN?
John Blakley
All,
I'm running Orion and just switched over our 3750s over the weekend with a 6509. Orion is seeing only VLAN1 as routed, even though I have 6 or 7 other vlans configured on the switch. Is there something special that I need to do on the 6509 to make a "routed" vlan, considering that it's routing traffic just fine?
I have the standard vlan 126, vlan 126 svi, and that'd be all...
126  VLAN0126                         active    Gi1/12, Gi1/14, Gi2/24, Gi3/1, Gi3/3, Gi3/5, Gi4/33, Gi4/35, Gi4/41, Po3, Po4
interface Vlan126
description SERVER SUBNET
ip address 10.126.100.5 255.255.255.0
end
I can't see any traffic utilization on anything other than VLAN1 in Orion and I'd like to.....
Thanks!
John
HTH, John *** Please rate all useful posts ***
Antonio Knox
Level 7
Level 7
Have you attempted to re-discover the device? That may help, if you haven't done that already.
Antonio Knox
Level 7
Level 7
You definitely pointed me in the right direction! I relisted the resources on the switch, and apparently Orion will show both VLAN 1 (Unrouted) and VLAN1 (routed). All of my L3 svis were unselected, only showing the L2 vlan interface (unrouted). I unselected those and now they only show the L3 svis....
Thanks!
John
