6509-E stuck on route processor
ahmed.gadi
I have 6509-E currently running s72033-adventerprisek9-mz.151-2.SY2.
I tried to upgrade it to s72033-adventerprisek9-mz.151-2.SY4a, it gets stuck at route processor. I tried to revert back to current version and it boots up well.
Please check the console messages while upgrade.
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot disk0:s72033-adventerprisek9-mz.151-2.SY4a.bin"
Loading image, please wait ...
Initializing ATA monitor library...
Self extracting the image... [OK]
Self decompressing the image : ###################################################################################################
[OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVENTERPRISEK9-M), Version 15.1(2)SY4a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Mon 22-Dec-14 15:23 by prod_rel_team
Image text-base: 0x4010A2B8, data-base: 0x428912A0
*Apr 17 07:19:44.603: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Apr 17 07:19:44.603: %PFREDUN-6-STANDBY: Initializing as STANDBY processor for this switch
*Apr 17 07:19:46.199: %SYS-SPSTBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Apr 17 07:19:44.803: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 26-Aug-14 01:09 by integ Build [25856]
*Apr 17 07:19:46.199: %OIR-SPSTBY-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2009 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ######################################################################################################################################################################################################################################################### [OK]
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph
           cisco Systems, Inc.
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)SY4a, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2014 by Cisco Systems, Inc. Compiled Mon 22-Dec-14 15:05 by prod_rel_team
Image text-base: 0x4010C258, data-base: 0x451EB240
it stuck here...
Ihave 512MB DRAM as well as 512MB FLASH as required for IOS.
Looking forward to hear from someone.
Thanks & Regards
Ahmed...
Charles Hill
Hi Ahmed,
Possible corrupt ios.
Did you do a md5 checksum on the ios?
Hope this helps,
Please remember to rate helpful posts.
Thanks.
I tried it, and its verified.
verify /md5 disk0:s72033-adventerprisek9-mz.151-2.SY4a.bin 41b653cbc417ecef7eb76ea82c2edaee
....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
Verified (disk0:s72033-adventerprisek9-mz.151-2.SY4a.bin) = 41b653cbc417ecef7eb76ea82c2edaee
Thanks & Regards
Ahmed...
Dear All,
After going through the cisco documentation, I found that this is an expected behavior.
The RPR redundancy state (standby sup in STANDBY COLD state) it’s absolutely expected to see standby booting only to to some point.
It passes the console owership to RP and hungs.
The bootup process continues when the switchover happens.
You can find the confirmation in the following document:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/redund.html#wp1023627
The fact that standby sup is not fully booted is also mentioned in the following document:
