Catalyst 2960-x series. Static IP device was not able to get connection.
derrick.chan1
We recently purchase a cisco switch catalyst 2960-x series. 1 of the port seems to be refreshing 1 network point frequently, then another port connected to a static IP printer is down too, I couldn't ping the IP address. But when I change to Another switch, it is working fine.
I did a direct connect from that port to my laptop was ok but strangely why is it not working for a static IP printer?
Is there any configuration regarding connecting static IP?
Hi Derrick,
It is tough to answer based on above information. But can you please ensure the switch port is in the right vlan for that subnet from where you used the static ip?  Alternately you can check which vlan that port belongs to and configure an ip address from that vlan to the printer.
Also share all relevant details. From where you are pinging ? Are you on the same vlan or different vlan? Share port config etc so that we can help you further.
Hope this helps and kindly grade my post if it is helpful to you.
Madhu
Hi krishnan,
I just try show run and the result seems to hang at interface GigabitEthernet1/0/12..
586521b3#
586521b3#show run
Building configuration...
Current configuration : 1549 bytes
! Last configuration change at 02:31:25 UTC Wed Apr 29 2015
version 15.0
no service pad
hostname 586521b3
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 ip address dhcp
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
We have not configure any Vlan  for subnet.
Derrick
Hi Derrick.
You said output hangs at Gi1/0/12?
What happens if you press the [Space] bar on your keyboard? Please try that if you haven't already done so and post the results.
I'll do my best to help you.
John
John Hobbs
Houston, TX USA
- a Friendly American
