6509-E supervisor upgrade - bootflash vs sup-bootdisk
vd123_cisco
Hi All,
We have a business requirement to upgrade the supervisor engines from SUP engine 32 to Sup 2T on 6509-E
I would like to know what IOS would be compatible with the new SUP 2T. Currently we are running the following IOS
s3223-ipservicesk9_wan-mz.122-33.SXH3a.bin
Also this image is saved under sup-bootdisk:/
and there is another image saved under bootflash: c6msfc2a-pk9sv-mz.122-17d.SXB11a.bin
Do we need to upgrade the image stored under bootflash as well? i can see the bootvar is pointing to s3223-ipservicesk9_wan-mz.122-33.SXH3a.bin
#show bootvar
BOOT variable = sup-bootdisk:s3223-ipservicesk9_wan-mz.122-33.SXH3a.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby is up
Standby has 524288K/65536K bytes of memory.
Standby BOOT variable = sup-bootdisk:s3223-ipservicesk9_wan-mz.122-33.SXH3a.bin,1;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
Can someone please  explain the difference between bootflash: and Sup-bootdisk
What is importance of the image saved under bootflash:? if possible, can someone provide a link to learn more about 6500
Thanks in advance
Jay
Reza Sharifi
Here is a good doc to read regarding bootflash and sup-bootdisk.  The good news in on the new Sup-2T, you just have one boot disk that is located on MSFC5 and that is where you load the IOS,
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_c67_457347.html
Info on sup-2T:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-676346.html
As for the image, IOS 15.01SY1 is pretty stable and have not seen a lot of issues with it.
Reza Sharifi
Info on sup-2T:
Thank you Reza.
how did you fix the issue. ?
