6509 IDS & Firewall Module
Following configuration is configured :
Can Any one brief it .....
& What are Show command for the same ....So i can aget Output ........
firewall module 8 vlan-group [Group_ID]
firewall vlan-group XX [Vlan_Number]
firewall vlan-group XX [Vlan _Number]
intrusion-detection module 7 management-port access-vlan [Vlan_Number]
intrusion-detection module 7 data-port 1 capture
intrusion-detection module 7 data-port 1 capture allowed-vlan [Vlan_Number]
intrusion-detection module 7 data-port 1 autostate include
uwe.kadner
for the firewall part use that one http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/command/reference/fwsm_ref.html. For the you may start with 'show run | include intrusion-detection' or read through http://www.cisco.com/en/US/docs/security/ips/7.0/configuration/guide/cli/cliguide7.html.
uk.
