Runt and Giant Packet
cisco
what will happen when a device gets a runt and giant packet.
regards
Neo
mlund
Level 7
Level 7
Hi Neo
They will be discarded.
Giants:
Description: CatOS sh port and Cisco IOS sh interfaces and sh interfaces counters errors. Frames received that exceed the maximum IEEE 802.3 frame size (1518 bytes for non-jumbo Ethernet) and have a bad Frame Check Sequence (FCS).
Common Causes: In many cases, this is the
result of a bad NIC. Try to find the offending device and remove it from the network.
Platform Exceptions: Catalyst Cat4000
Series that run Cisco IOS Previous to
software Version 12.1(19)EW, the giants
counter incremented for a frame > 1518bytes.
After 12.1(19)EW, a giant in show interfaces increments only when a frame is received >1518bytes with a bad FCS.
Runts:
The frames received that are smaller than the minimum IEEE 802.3 frame size (64 bytes for Ethernet), and with a bad CRC.
Common Causes: This can be caused by a
duplex mismatch and physical problems, such as a bad cable, port, or NIC on the attached device.
Platform Exceptions: Catalyst 4000 Series
that run Cisco IOS Previous to software
Version 12.1(19)EW, a runt = undersize.
Undersize = frame < 64bytes. The runt counter only incremented when a frame less than 64 bytes was received. After 12.1(19EW, a runt = a fragment. A fragment is a frame < 64 bytes but with a bad CRC. The result is the runt counter now increments in show interfaces, along with the fragments counter in show interfaces counters errors when a frame <64 bytes with a bad CRC is received.
/Mikael
jbrenesj
Level 3
Level 3
Just wanted to add something..
Most switches could report 801.1q tagged frames as giants and they won't get dropped. This happens if a frames that is coming to the switch is 1518 bytes long + 4 bytes of dot1q = 1522
The switch will strip the tag, report the giant but will still let the frame get in without getting dropped.
If you see a giant, what you do is check the:
Core3560#sh controllers ethernet-controller f0/1
Look for:
- Invalid frames, too large
- Valid frames, too large
Example:
sh int fa 0/1 sees 288 giants but sh controller eth f0/1 sees 288 Valid frames, too large ===== no problem
