6509:%OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
Rosa Ladeira
Jul 25 20:40:52 singer-outside 41: 00:03:01: %OIR-SP-6-INSCARD: Card
Jul 25 20:40:52 singer-outside 42: 00:03:01: %OIR-SP-6-INSCARD: Card
inserted in slot 7, interfaces are now online
Jul 25 20:40:53 singer-outside 43: 00:03:06: %DIAG-SP-6-DIAG_OK: Module
2: Passed Online Diagnostics
Jul 25 20:40:53 singer-outside 44: 00:03:08:
%SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 147.65.1.96 port 514
started - reconnection
Jul 25 20:40:56 singer-outside 45: 00:03:09: %OIR-SP-6-INSCARD: Card
inserted in slot 2, interfaces are now online
Jul 25 21:00:12 singer-outside 46: 00:22:26: %CPU_MONITOR-6-NOT_HEARD:
CPU_MONITOR messages have not been heard for 30 seconds [5/0]
Jul 25 21:00:28 singer-outside 47: 00:22:42:
%ERR_DET-5-ERR_DET_NO_EOBC_INPUT: No EOBC input, dump debuginfo,
interval 10, times 3
Jul 25 21:00:43 singer-outside 48: 00:22:57: %CPU_MONITOR-6-NOT_HEARD:
CPU_MONITOR messages have not been heard for 61 seconds [5/0]
Jul 25 21:01:13 singer-outside 49: 00:23:27: %CPU_MONITOR-6-NOT_HEARD:
CPU_MONITOR messages have not been heard for 91 seconds [5/0]
Jul 25 21:01:43 singer-outside 50: 00:23:57: %CPU_MONITOR-6-NOT_HEARD:
CPU_MONITOR messages have not been heard for 121 seconds [5/0]
Jul 25 21:07:02 singer-outside 42: 00:03:08: %OIR-SP-6-INSCARD: Card
Jul 25 21:07:02 singer-outside 43: 00:03:08: %DIAG-SP-6-DIAG_OK: Module
Jul 25 21:07:03 singer-outside 44: 00:03:17:
%SYS-6-LOGGINGHOST_STARTSTOP: does anybody know what cause this error on cisco 6509?
Jul 25 21:07:10 singer-outside 45: 00:03:20: %OIR-SP-6-INSCARD: Card
Jul 25 21:07:33 singer-outside 46: 00:03:41: %OIR-SP-6-INSCARD: Card
Jul 25 22:00:13 singer-outside 41: 00:03:07: %DIAG-SP-6-DIAG_OK: Module
Jul 25 22:00:13 singer-outside 42: 00:03:08: %OIR-SP-6-INSCARD: Card
Jul 25 22:00:14 singer-outside 43: 00:03:15:
Jul 25 22:00:22 singer-outside 44: 00:03:20: %OIR-SP-6-INSCARD: Card
Jul 25 22:00:56 singer-outside 45: 00:03:50: %OIR-SP-6-INSCARD: Card
Jul 25 22:16:38 singer-outside 46: 00:19:26: %SYS-SP-3-CPUHOG: Task is
running for (2004)msecs, more than (2000)msecs (0/0),process = TYFIB
Table Manager.
Jul 25 22:16:38 singer-outside 47: -Traceback= 417502E4 41751C28
41751E50 4175A428 409D3BA4 409D3B90
Jul 25 22:33:57 singer-outside 42: 00:02:55: %OIR-SP-6-INSCARD: Card
inserted in slot 9, interfaces are now online
Jul 25 22:34:00 singer-outside 43: 00:03:06:
Jul 25 22:34:00 singer-outside 44: 00:03:06: %DIAG-SP-6-DIAG_OK: Module
Jul 25 22:34:34 singer-outside 45: 00:03:40: %OIR-SP-6-INSCARD: Card
Jul 25 22:50:02 singer-outside 43: 00:03:09: %DIAG-SP-6-DIAG_OK: Module
Jul 25 22:50:06 singer-outside 44: 00:03:20:
Jul 25 22:50:34 singer-outside 45: 00:03:47: %OIR-SP-6-INSCARD: Card
Jul 25 23:08:15 singer-outside 40: 00:02:58: %DIAG-SP-6-DIAG_OK: Module
7: Passed Online Diagnostics
Jul 25 23:08:20 singer-outside 41: 00:03:07:
Jul 25 23:08:23 singer-outside 42: 00:03:10: %DIAG-SP-6-DIAG_OK: Module
Jul 25 23:08:26 singer-outside 43: 00:03:13: %OIR-SP-6-INSCARD: Card
Jul 25 23:08:31 singer-outside 44: 00:03:20: %OIR-SP-6-INSCARD: Card
Jul 25 23:08:46 singer-outside 45: 00:03:32: %OIR-SP-6-INSCARD: Card
Jul 25 23:16:56 singer-outside 41: 00:03:06: %DIAG-SP-6-DIAG_OK: Module
Jul 25 23:17:00 singer-outside 42: 00:03:16:
Jul 25 23:17:00 singer-outside 43: 00:03:17: %OIR-SP-6-INSCARD: Card
Jul 25 23:17:08 singer-outside 44: 00:03:23: %OIR-SP-6-INSCARD: Card
Jul 25 23:17:22 singer-outside 45: 00:03:36: %OIR-SP-6-INSCARD: Card
Jul 25 23:32:39 singer-outside 42: 00:02:56: %OIR-SP-6-INSCARD: Card
Jul 25 23:32:42 singer-outside 43: 00:03:06:
Jul 25 23:32:48 singer-outside 44: 00:03:11: %DIAG-SP-6-DIAG_OK: Module
Jul 25 23:33:33 singer-outside 45: 00:03:52: %OIR-SP-6-INSCARD: Card
Jul 25 23:41:08 singer-outside 42: 00:02:59
9 Replies 9
Leo Laohoo
What's the question?
It indicates the modules are either being removed/replaced, rebooted, or crashing
Yes, but how can I find out which one is going on ? reboot or crash? Is This a supervisor crash?
No one is removing/replacing modules.
I have heard about power problems?
Should it be caused by ip pontes Powered over ethernet cables?
Rosa
I do not know what should I to do in order to identify the cause of These messages.
Modules are download.
Have You ever seen those messages ?
Thaínks
Rosa
One thing I see is that there are moments with no frames on EOBC (shared comunication medium):
Possible reasons this behavior could be that one of the modules or supervisor are faulty and jam EOBC. System do not hear messages from modules due to jam and resets those automatically in an attempt to recover.
I suggest to take out all modules and insert one by one checking switch stability after each new linecard inserted. Then either you find out one module that is triggerring the problem or the problem won't be reproduced. If latter, then root cause was in misseated linecard.
If any module is reloading in the chassis with only supervisor in it, then supervisor or chassis are at fault. You can further narrow down by changing sup or trying in another chassis.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Thanks Ivan.
That was what we did the last two days.
We found out a user that had connected a switch/hub at his office (without authorization)
and had also connected a cable  (a loop) from port 7 to port 8 of this switch.
The problem stops when shutting down  the user office port connected to Cisco 6509.
Have you heard about this ?
Rosa
Hi Rosa,
Potentially the same could be seen if CPU on supervisor was at 100%, unable to reply on keepaloves from modules. Did you have a chance to check CPU utilization during the issue?
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Thanks, Ivan.
I will try the experiment latter, in an appropriate occasion.
I guess  I will get 100% of cpu usage.
Regards Rosa
I'm a bit skeptical that modules would timeout, even during an STP loop where CPU is 100%.  But I suppose with older hardware or an older IOS version and under certain other conditions, it would be possible.
Rosa - I'd recommend entering configuration mode and adding either of these commands:
spanning-tree portfast bdpufilter default or spanning-tree portfast bpduguard default
Either of these commands will help to mitigate against the loop automatically.
