6509 : power-supply incompatible with fan
Rosa Ladeira
I have a 6509 box with the following modules:
Router#sh module all
Mod Ports Card Type                              Model              Serial No.
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL10382D4T
  9   16  SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX     SAD061100X6
Mod MAC addresses                       Hw    Fw           Sw           Status
  5  0013.c320.7d54 to 0013.c320.7d57   5.6   8.4(2)       12.2(18)SXF1 Ok
  9  0001.63d7.0b92 to 0001.63d7.0ba1   2.1   6.3(1)       8.5(0.46)RFW Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1023R0AW  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL103826J1  2.7    Ok
Mod  Online Diag Status
  5  Pass
  9  Pass
Router#
System is shutting down with the message above:
00:06:13: %C6KENV-SP-2-SHUTDOWN: shutdown power-supply 1 now because of incompatible with fan.
00:06:14: %C6KPWR-SP-2-PSFAIL: power supply 1 output failed.
00:06:14: %C6KENV-SP-2-SHUTDOWN: shutdown power-supply 2 now because of incompatible with fan.
show inventory command does not show any fan :
Router#sh inventory
NAME: "WS-C6509", DESCR: "Cisco Systems Catalyst 6500 9-slot Chassis System"
PID: WS-C6509          , VID:    , SN: TBM06124103
NAME: "WS-C6K-VTT 1", DESCR: "VTT FRU 1"
PID: WS-C6K-VTT        , VID:    , SN: SMT0609D809
NAME: "WS-C6K-VTT 2", DESCR: "VTT FRU 2"
PID: WS-C6K-VTT        , VID:    , SN: SMT0609C421
NAME: "WS-C6K-VTT 3", DESCR: "VTT FRU 3"
PID: WS-C6K-VTT        , VID:    , SN: SMT0609C394
NAME: "WS-C6000-CL 1", DESCR: "C6K Clock FRU 1"
PID: WS-C6000-CL       , VID:    , SN: SMT0607C685
NAME: "WS-C6000-CL 2", DESCR: "C6K Clock FRU 2"
PID: WS-C6000-CL       , VID:    , SN: SMT0609B897
NAME: "5", DESCR: "WS-SUP720-3B 2 ports Supervisor Engine 720 Rev. 5.6"
PID: WS-SUP720-3B      , VID: V05, SN: SAL10382D4T
NAME: "msfc sub-module of 5", DESCR: "WS-SUP720 MSFC3 Daughterboard Rev. 2.7"
PID: WS-SUP720         , VID:    , SN: SAL103826J1
NAME: "switching engine sub-module of 5", DESCR: "WS-F6K-PFC3B Policy Feature Card 3 Rev. 2.3"
PID: WS-F6K-PFC3B      , VID: V01, SN: SAL1023R0AW
NAME: "9", DESCR: "WS-X6516-GE-TX SFM-capable 16 port 10/100/1000mb RJ45 Rev. 2.1"
PID: WS-X6516-GE-TX    , VID:    , SN: SAD061100X6
NAME: "PS 1 WS-CAC-1300W", DESCR: "110/220v AC power supply, 1360 watt 1"
PID: WS-CAC-1300W      , VID:    , SN: SNI06090507
NAME: "PS 2 WS-CAC-1300W", DESCR: "110/220v AC power supply, 1360 watt 2"
PID: WS-CAC-1300W      , VID:    , SN: SNI06440186
Router#
Post the command of
show env
it should have the FAN module version.
Also, when the data sheet said 2500W power supply, it doesn't mean that you have have combine power of 2500W (1300+1300). It means that you need to have individual 2500W power supplies (2500+2500).
jerry
Jerry Ye
You need mimimum of 2500W powers per power supply. You set up is not supported.
Also, I don't see what FAN module is in the chassis, I am hoping you are using FAN2 if it is not a E chassis.
Please see Table-5 of the following link for more detail:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856_ps2797_Products_Data_Sheet.html
HTH,
jerry
I can not understand why fan module is not visible. Any suggestion ?
I have combined power supply and as you have said it is not enougth
Router(config)#power redundancy-mode combined
Router(config)#exit
Router#sh power status all
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-1300W       1153.32 27.46  OK     OK     on
2    WS-CAC-1300W       1153.32 27.46  OK     OK     on
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
5    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
6    (Redundant Sup)       -     -      282.24  6.72  -     -
9    WS-X6516-GE-TX      144.90  3.45   144.90  3.45  on    on
Router#sh power redundancy-mode
system power redundancy mode = combined
Post the command of
show env
jerry
You are right !
Router#sh env
environmental alarms:
system minor alarm on power-supply 1 incompatible with fan (raised 00:00:46 ago)
system minor alarm on power-supply 2 incompatible with fan (raised 00:00:45 ago)
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-9SLOT-FAN2
  fan-tray 1 version: 2
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 28C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 26C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 30C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-fail: OK
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 0C
  module 5 inlet temperature: 0C
  module 5 device-1 temperature: 0C
  module 5 device-2 temperature: 0C
  module 5 asic-1 temperature: 0C
  module 5 asic-2 temperature: 0C
  module 5 asic-3 temperature: 0C
  module 5 asic-4 temperature: 0C
  module 5 asic-5 temperature: 0C
  module 5 asic-6 temperature: 0C
  module 5 RP outlet temperature: 27C
  module 5 RP inlet temperature: 28C
  module 5 EARL outlet temperature: 32C
  module 5 EARL inlet temperature: 23C
module 9:
  module 9 power-output-fail: OK
  module 9 outlet temperature: N/O
  module 9 inlet temperature: N/O
chassis connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 5
  module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 5 power consumption: 282.24 Watts ( 6.72 Amps @ 42V)
module 9
  module 9 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 9 power consumption: 144.90 Watts ( 3.45 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
ambient temperature: < 55C
  module 5 cooling requirement: 35 cfm
  module 9 cooling requirement: 30 cfm
