6509 Sup Modules
daveschmeltz
Community Member
Are 6509 Sup Modules, "Hot-Swappable"? I have a 6509 that has two sup modules in it and I need to take one out...Can I do this safely without turning off the switch?
CyberDjinn
yes
ankbhasi
Hi Dave,
Yes the sup modules, the line cards , the power supplies are all hot swappable in cat6500 series switch.
So you can go ahead with removal of the sup engine without turning off the switch.
Ankur
*pls rate all helpfull post
