6509 VSS active/active
vpersaud001
Level 3
Level 3
I configured two 6509s per the configuration guide and they work as expected until I reload the switch. Upon reload both switches come up as active/active instead of active/standby. At the moment I only have the sup blades installed. Also the port-channel configuration on switch-2 disappears.
Is this normal behavior or am I missing some config?
The ios is 12.2(33)SXH6.
Any ideas what could be the issue?
Thank you very much for any help.
vpersaud001
Level 3
Level 3
Issue resolved!!!!
When initially configuring switch 1 did not take the command "switch accept mode virtual". I converted both switches to stand alone, re-enterd the VSS configs and entered the above command after the standby switch initalized.
All is well now!
