6509 VSS loopback ip 127.0.0.x
karamalomari
I am seeing IP Address 127.0.0.x is being discovered in our NAC solution generated from C6509-E with SUP2T and the IOS version is 15.5.1SY10.
Is there any specific command to display from where this ip address is being generated on the VSS switches?
DanielP211
Hello!
That seems weird. Could you check show ip int brief, to check if the ip is configured anywhere on the 6509?
BR
****Kindly rate all useful posts*****
karamalomari
I have executed "show tech-support" along with the full configuration file for "127.0." with NO luck.
Also, I have checked the arp table, cef, ...etc. 127 is not there which why i am confused from where this ip is coming.
