6509E Switch - Quick Question
Ahmed Hamdy
Visitor
Dear All,
1- If one of my customers has one core switch 6509E with two supervisors (VS-SUP2T-10G), it will support SSO and how to check this point ?
2- If we need to add SFP module (WSX6824-sfp) to the above mentioned switch, if this modules still available to be sale or not ?
Thank you.
Switch6509#sh redundancy
Redundant System Information :
Available system uptime = 44 weeks, 5 days, 11 hours, 50 minutes
Switchovers system experienced = 0
Standby failures = 0
 Last switchover reason = none
 Hardware Mode = Simplex
 Configured Redundancy Mode = sso
 Operating Redundancy Mode = sso   --> This point
 Maintenance Mode = Disabled
 Communications = Down      Reason: Simplex mode
Switch6509#sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6824-SFP
  2   24  CEF720 24 port 1000mb SFP              WS-X6824-SFP
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6848-GE-TX
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
==> It's support mode SSO
6 Replies 6
Joseph W. Doherty
#1 see if redundancy configured and active.
#2 I believe they still are, but you can check end-of-life announcements.
mamdohmardini
Level 2
Level 2
try the command show redundancy
Tai Nguyen
1. You can check by command: show redundancy or show module
2. Is it WS-X6824-SFP-2T= ?
1- I don't have access to the Switch, i'm the presales engineer and need to clarify this point.
2- Yes it WS-X6824-SFP-2T and already found it.
Thank you.
