6513 - Mod 9 recycling power - 10 gig 6704 card
dclee
Been troubleshooting this issue for a few days now..
I have 2 6513's between floors that have a port channel between them using 2 10 gig interfaces on 6704 cards
This weekend I lost the port channel for about 4 mins and then it came back up. Unfort at the time I had logging
turned off so was unable to get any info as to why. But I turned on debugging that eve and this morn it happened again.
Looks like Mod 9 is being power recycled, 6704 is about a year old and had been running for a month or so without issue.
The only thing I have upgraded in the last few weeks was I put in a pair of 6000w supplies..But I am not having any other issues
other than mod 9. Any ideas ?? In hind sight a better design would be to spread this port channel across 10 gig cards. I'll work on that next.
2w2d: %OIR-SP-3-PWRCYCLE: Card in module 9, is being power-cycled 'Off (Module Reset due to exception or user request)'
2w2d: %C6KPWR-SP-4-DISABLED: power to module in slot 9 set Off (Module Reset due to exception or user request)
*Mar 1 00:00:02.331: DaughterBoard (Centralized Forwarding Card)
Firmware compiled 15-Nov-11 14:23 by integ Build [100]
Feb 27 10:43:53.927: %SYS-CFC9-5-RESTART: System restarted --
Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXJ2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Dec-11 19:50 by prod_rel_team
Feb 27 10:43:53.931: CFC9: Currently running ROMMON from S (Gold) region
2w2d: %DIAG-SP-6-RUN_MINIMUM: Module 9: Running Minimal Diagnostics...
2w2d: %DIAG-SP-6-DIAG_OK: Module 9: Passed Online Diagnostics
2w2d: %OIR-SP-6-INSCARD: Card inserted in slot 9, interfaces are now online
Gurpreet Kochar
Most likely the line card stops responding to the supervisior and therefore the microcode of the line card is reloaded to attempt to bring it out of that situation.
Suggestions:-
1. Reseat the line card if it has not  been reseated
2. Move the line card to a different slot and see if the problem follows
3. Most likely you would end of getting the line card replaced. Open a TAC case and request for RMA.
Gurpreet Kochar
Suggestions:-
New card is on the way
I agree with point Gurpreet's #2.  You need to determine if the issue is the blade (good news) or the back-plane (bad news).
