6807 Management interface
Sec_guy
Frequent Visitor
Frequent Visitor
Greetings,
How can I access the management interface of 6807 Core switch as I can not see it in the configuration ?
Reza Sharifi
The mgmt interface for 6807 (sup2T) has its own firmware and that is separate from the main IOS and that is why you don't see it in the running config. It is called CMP.
Have a look this link on how to configure it.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/cmp_configuration/guide/sup2T_10GEcmp/cmp_overview.html
Reza Sharifi
BTW, CMP is not like a regular out-of-band management port that exist in 4500, 3850, 3650 and other platforms.  When you session to CPM, it takes you to the CPM module and than from there you have to session to the IOS to see the config.  Its a pain but thankfully Cisco has replaced it with a regular OOB  port in Sup-6T, which is much more useful.
Thanks for the great info.
