6807 VSS interfaces in switch 2 module 2 all down
Glenn R
I have a issue with a module in a VSS cluster using 6708 switches. There are around 60 multi chassis-etherchannel connections to access layer devices connected but I have a issue where all connection on one module are all showing down. The modules are powered up and showing no errors. Please see below:
CORE-01#sh power switch all
Switch Number: 1
system power redundancy mode = redundant
system power redundancy operationally = redundant(2+1)
system power total = 5699.72 Watts (109.61 Amps @ 52V)
system power used = 2917.20 Watts (56.10 Amps @ 52V)
system power available = 2782.52 Watts (53.51 Amps @ 52V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @52V Status Status State
1 C6800-XL-3KW-AC 2999.88 57.69 OK OK on
2 C6800-XL-3KW-AC 2999.88 57.69 OK OK on
3 C6800-XL-3KW-AC 2999.88 57.69 OK OK on
4 none
Pwr-Allocated Oper
Fan Type Watts A @52V State
1 C6807-XL-FAN 260.00 5.00 OK
Pwr-Allocated Oper
PwrCon Type Watts A @52V State
1 C6800-XL-PS-CONV 12.48 0.24 OK
2 C6800-XL-PS-CONV 12.48 0.24 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @52V Watts A @52V State State
1 C6800-32P10G 587.60 11.30 587.60 11.30 on on
2 C6800-32P10G 587.60 11.30 587.60 11.30 on on
3 VS-SUP2T-10G 434.72 8.36 434.72 8.36 on on
4 (Redundant Sup) - - 434.72 8.36 - -
5 C6800-32P10G 587.60 11.30 587.60 11.30 on on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit = 9100.00 Watts (175.00 Amps @ 52V)
system auxiliary connector power limit = 13000.00 Watts (250.00 Amps @ 52V)
system primary power used = 2917.20 Watts (56.10 Amps @ 52V)
system auxiliary power used = 0 Watt
Switch Number: 2
system power used = 2904.72 Watts (55.86 Amps @ 52V)
system power available = 2795.00 Watts (53.75 Amps @ 52V)
4 none
Pwr-Allocated Oper
Pwr-Allocated Oper
system primary power used = 2904.72 Watts (55.86 Amps @ 52V)
Group Port-channel Protocol Ports
1 Po1(SU) PAgP Te1/1/1(P) Te2/1/1(D)
2 Po2(SU) PAgP Te1/1/2(P) Te2/1/2(P)
3 Po3(SU) PAgP Te1/1/3(P) Te2/1/3(P)
4 Po4(SU) PAgP Te1/1/4(P) Te2/1/4(P)
5 Po5(SU) PAgP Te1/1/5(P) Te2/1/5(P)
6 Po6(SU) PAgP Te1/1/6(P) Te2/1/6(P)
7 Po7(SU) PAgP Te1/1/7(P) Te2/1/7(P)
8 Po8(SU) PAgP Te1/1/8(P) Te2/1/8(P)
9 Po9(SU) PAgP Te1/1/9(D) Te2/1/9(P)
10 Po10(SU) PAgP Te1/1/10(P) Te2/1/10(P)
11 Po11(SU) PAgP Te1/1/11(P) Te2/1/11(P)
12 Po12(SU) PAgP Te1/1/12(P) Te2/1/12(P)
13 Po13(SU) PAgP Te1/1/13(P) Te2/1/13(P)
14 Po14(SU) PAgP Te1/1/14(P) Te2/1/14(P)
15 Po15(SU) PAgP Te1/1/15(D) Te1/5/20(P) Te2/1/15(D)
Te2/5/20(P)
16 Po16(SU) PAgP Te1/1/16(P) Te2/1/16(P)
17 Po17(SU) PAgP Te1/1/17(P) Te2/1/17(P)
18 Po18(SU) PAgP Te1/1/18(P) Te2/1/18(P)
19 Po19(SU) PAgP Te1/1/19(P) Te2/1/19(P)
20 Po20(SU) PAgP Te1/1/20(P) Te2/1/20(P)
21 Po21(SU) PAgP Te1/1/21(P) Te2/1/21(P)
22 Po22(SU) PAgP Te1/1/22(P) Te2/1/22(P)
23 Po23(SU) PAgP Te1/1/23(P) Te2/1/23(P)
24 Po24(SU) PAgP Te1/1/24(P) Te2/1/24(P)
25 Po25(SU) PAgP Te1/2/1(P) Te2/2/1(D)
26 Po26(SU) PAgP Te1/2/2(P) Te2/2/2(D)
27 Po27(SU) PAgP Te1/2/3(P) Te2/2/3(D)
28 Po28(SU) PAgP Te1/2/4(P) Te2/2/4(D)
29 Po29(SU) PAgP Te1/2/5(P) Te2/2/5(D)
30 Po30(SU) PAgP Te1/2/6(P) Te2/2/6(D)
31 Po31(SU) PAgP Te1/2/7(P) Te2/2/7(D)
32 Po32(SU) PAgP Te1/2/8(P) Te2/2/8(D)
33 Po33(SU) PAgP Te1/2/9(P) Te2/2/9(D)
34 Po34(SU) PAgP Te1/2/10(P) Te2/2/10(D)
35 Po35(SU) PAgP Te1/2/11(P) Te2/2/11(D)
36 Po36(SU) PAgP Te1/2/12(P) Te2/2/12(D)
37 Po37(SU) PAgP Te1/2/13(P) Te2/2/13(D)
38 Po38(SU) PAgP Te1/2/14(P) Te2/2/14(D)
39 Po39(SU) PAgP Te1/2/15(P) Te2/2/15(D)
40 Po40(SU) PAgP Te1/2/16(P) Te2/2/16(D)
41 Po41(SU) PAgP Te1/2/17(P) Te2/2/17(D)
42 Po42(SU) PAgP Te1/2/18(P) Te2/2/18(D)
43 Po43(SU) PAgP Te1/2/19(P) Te2/2/19(D)
44 Po44(SU) PAgP Te1/2/20(P) Te2/2/20(D)
45 Po45(SU) PAgP Te1/2/21(P) Te2/2/21(D)
46 Po46(SU) PAgP Te1/2/22(P) Te2/2/22(D)
47 Po47(SU) PAgP Te1/2/23(P) Te2/2/23(D)
48 Po48(SD) -
49 Po49(SD) -
50 Po50(SU) PAgP Te1/2/26(P) Te2/2/26(D)
51 Po51(SU) PAgP Te1/2/27(P) Te2/2/27(D)
111 Po111(SU) - Te1/5/9(P) Te1/5/10(P)
112 Po112(SU) - Te2/5/9(D) Te2/5/10(P)
115 Po115(SU) PAgP Te1/5/31(P) Te1/5/32(P)
As you will see all connections are working for modules 1 and 5 on switch 2 but not for module 2
Has anyone ever seen this or had the same issue
Glenn
Glenn R
No one ?
Hi both chassis are effected looking at that output , what way are these physically setup , is it a link off each chassis connected to 1 access switch  in a triangle yes ?
to start with need to see the configs and what ways its cabled as these are ether channels failures , miss config can cause this   , can you post the below interfaces and the configs off the connecting switches that there linked to and also the cdp off each of the VSS and the connected access switches below to start with to see the setup
is it the same for LACP to rule out the protocol
have you checked for STP issues on these interfaces , all forwarding etc not blocking
