6840-X stuck at boot
michael-d
Hello
We have an new 6840-X which is stuck at the system bootstrap.
The console displays:
"System Initializing
System bootstrap, Version 15.2(02)SY [Rel 1.0], RELEASE SOFTWARE
Current image running: Transformer Boot Rom : Upgradable Region
Last reset cause: Front Panel Reset, reset code 0x2"
We have tried to power cycle the unit and reset thru the reset button.
Any suggestions?
Michael
andrewswanson
Level 7
Level 7
Hi - how did you resolve your issue? Did you have to RMA the switch?
Andy
Hi Andy
Actually it was quite simple. After initial setup and reboot the active console port switched from USB to serial even though I made changes to console port setup. But when I used the serial port instead everything was ok :)
Michael
Thanks for the update Michael. My issue was due to lack of boot variables/statements and is also now resolved - see thread below:
https://supportforums.cisco.com/t5/lan-switching-and-routing/6880-booting-issue/td-p/3367948
Cheers
Andy
