6880 with VSS;
t.piening
 Are there any preferred Ports for the VSL Links between two 6880 Chassis? Thanx for any Help
Naveen Venkateshaiah
virtual Switching link can be configured on both 1-Gigabit and 10-Gigabit port.
Pls check this link
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6880_x/hardware/installation/guide/b_c6880-X_hig/b_c6880-X_hig_chapter_01.html
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6880-x-switch/white_paper_c11-728540.htm
Naveen
****rate if it is helpful****
Thank you Naveen
but I mean the Port Number 1-16, Can I use One Or two of this 16 Ports Or can I use only Port 1 and 2 äs VSL Links
regards Thomas
it better configure on ten gig link te5/15-16 ports.
Naveen
