7206 802.1q troubles
shanemason
I am trying to get a 802.1q trunk configured on a Gigabit interface on a 7206VXR. There is no enaps 8021q option in the interface config. Any ideas? The only 802.1q option at all is for tunneling. Thanks in advance for your help!
You would need an IP Plus feature set of IOS image if you want to configure the subinterface with encapsulation dot1q.
Please use the link below for finding the right IOS for the router. Check using the feature navigator tool:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
You have to check the memory and flash memory requirement. You currently have 256MB Dram and 64MB flash card and 16MB internal flash.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/swtch_r/swi_e1.htm#wp1071331
HTH,Please rate if it does.
-amit singh
ankbhasi
Hi Friend,
Can you paste the output of "sh version"?
Ankur
MACNGAMTRTR01# sh ver
Cisco IOS Software, 7200 Software (C7200-IK9S-M), Version 12.4(7), RELEASE SOFTW ARE (fc6)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 01-Mar-06 05:13 by alnguyen
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(9), RELEASE SOFTWARE (fc2)
MACNGAMTRTR01 uptime is 29 weeks, 6 days, 16 hours, 29 minutes
System restarted at 17:55:55 Eastern Wed Nov 1 2006
System image file is "disk2:c7200-ik9s-mz.124-7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory.
Processor board ID 33633335
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.9
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 200 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 200 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
12 Serial interfaces
8 Channelized T1/PRI ports
509K bytes of NVRAM.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
-amit singh
