restart http process
lydia.walther
how can we restart the http process on a 3750 switch without reloading the device?
Amit Singh
Try disabling and re-enabling the http service on the switch by using " no ip http server " command. this should reset the service on the switch. Check if that helps.
Please rate if it does.
-amit singh
we tried that and it didn't help. The process seems to hang. We get a timeout when we telnet to port 80 of the device. CNA shows a broken connection symbol as well. Is there any other way to stop and restart a process?
Amit Singh
Nope there is no other way to kill and individual process on 3750. You have to reboot it.
-amit singh
