7507 hardware problems
jasonbegley
Frequent Visitor
Frequent Visitor
I have a 7507 in my lab and when placing cards in slots 4-6 I get the errors below. I was wondering what part of the chassis could be at fault.
00:05:08: %RSP-3-ERROR: Error detected on CyBus1, Error code 78
00:05:08: %RSP-3-ERROR: address parity error 23:16 1, 15:8 1, 7:0 1
00:05:08: %RSP-3-ERROR: virtual address (bits 23:17) FE0000
00:05:08: %RSP-3-ERROR: virtual address corresponds to slot15
00:05:10: %RSP-3-ERROR: End of MEMD error interrupt processing
00:05:10: %RSP-3-ERROR: Error detected on CyBus1, Error code 78
00:05:10: %RSP-3-ERROR: address parity error 23:16 1, 15:8 1, 7:0 1
00:05:10: %RSP-3-ERROR: virtual address (bits 23:17) FE0000
00:05:10: %RSP-3-ERROR: virtual address corresponds to slot15
00:05:12: %RSP-3-ERROR: End of MEMD error interrupt processing
00:05:12: %OIR-6-INSCARD: Card inserted in slot 4, interfaces administratively shut down
00:05:12: %RSP-3-ERROR: Error detected on CyBus1, Error code 78
00:05:12: %RSP-3-ERROR: address parity error 23:16 1, 15:8 1, 7:0 1
00:05:12: %RSP-3-ERROR: virtual address (bits 23:17) FE0000
00:05:12: %RSP-3-ERROR: virtual address corresponds to slot15
00:05:14: %RSP-3-ERROR: End of MEMD error interrupt processing
00:05:15: %CBUS-3-CMDTIMEOUT: Cmd timed out, CCB 0xF800FF50, slot 4, cmd code 0 -Traceback= 0x403551EC 0x40575A28 0x405773D0 0x4056EC48 0x405735F8 0x40565494
00:05:17: %SYS-3-CPUHOG: Task is running for (2004)msecs, more than (2000)msecs (505/505),process = RSP Background.
-Traceback= 0x4045DF00 0x40568C68 0x4055111C
00:05:19: %SYS-3-CPUHOG: Task is running for (4008)msecs, more than (2000)msecs (505/505),process = RSP Background.
-Traceback= 0x40568C68 0x4055111C
00:05:21: %SYS-3-CPUHOG: Task is running for (6012)msecs, more than (2000)msecs (505/505),process = RSP Background.
-Traceback= 0x4045DF64 0x40568C68 0x4055111C
00:05:23: %SYS-3-CPUHOG: Task is running for (8016)msecs, more than (2000)msecs (505/505),process = RSP Background.
-Traceback= 0x4045DF50 0x40568C68 0x4055111C
00:05:25: %SYS-3-CPUHOG: Task is running for (10020)msecs, more than (2000)msecs (505/505),process = RSP Background.
-Traceback= 0x4045DF2C 0x40568C68 0x4055111C
00:05:27: %SYS-3-CPUHOG: Task is running for (12024)msecs, more than (2000)msecs (505/505),process = RSP Background.
00:05:29: %SYS-3-CPUHOG: Task is running for (14028)msecs, more than (2000)msecs (505/505),process = RSP Background.
-Traceback= 0x4045DF1C 0x40568C68 0x4055111C
00:05:30: %RSP-3-ERROR: dbus read at 3E841042
-Traceback= 0x4055C888 0x40575E3C 0x4056D454 0x4058F2A8 0x4058F430 0x400E07A8 0x400EE52C
-Traceback= 0x4055C888 0x40575E3C 0x4056D7C4 0x4058F2B8 0x4058F430 0x400E07A8 0x400EE52C
00:05:47: %RSP-3-ERROR: dbus read at 3E841042
00:06:15: %DBUS-3-PERMANENT_WEDGED: Line card in slot 4 is permanently wedged
00:06:17: %RSP-3-ERROR: dbus read at 3E841042
dsweeny
Level 6
Level 6
In a Cisco 7507 or Cisco 7513 system, OIR (On-line Insertion and Removal) of any xIP or VIP on either CyBus may cause the slave RSP2 to reboot with a bus error or a processor memory parity error. The master RSP will recover from this event by issuing a "Cbus Complex Restart.Refer URL
http://www.cisco.com/en/US/products/hw/routers/ps359/products_field_notice09186a0080094c75.shtml
