7600 QoS Issues with juniper
DIEGO ZORRILLA
I´m having some issues with frames going into a 7600 with ToS value, but when going out from the 7600 dont have any more the ToS value.
This is happening when the source of the ip packets is a juniper.
Ruben Cocheno
probably you have a mls qos implemented, so that means the router will remove the ToS value unless you trust that outgoing interface and configure the interface like mls qos trus cos and mls qos trust dscp
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Hi Rcochenos,
Turns out to be a but, you know is always a bug, and it fix by removing and adding again the mls qos trust lines.
LCs ES20 seems not to be hit by the bug, it also seems just hit 12.2(33)SRE6
you can verify if its affecting you witht he command
remote command switch show qm-sp port-data "LC" "Port"
* Queuing Mode [COS]
* Type: Tx[COS to Q - 1p3q8t] Rx[COS to Q - 1q8t]
* Per-Port: Trust[Untrusted] Default COS[0] Override[1] [VLAN based]
