7606S booting to Rommon..Help!!
een4hc007
Hi Everyone,
We have a 7606s router with 2 x RSP720-3C-10GE running. The router,when power cycled, goes to rommon for indefinitely.
Below are the exercises that we have done so far:
During the initial rommon, we could deduce
Devices in device table:
      id name
 bootdisk: PCMCIA boot disk
    disk0: PCMCIA disk 0
We then had dir disk0:
PCMCIA disk0: device is not initialized
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
dir: cannot open device "disk0:"
Also dir bootdisk
bootdisk:c7600rsp72043-advipservices-mz.122-33.SRE5.bin
However router only comes back by setting configure register value to 0x2102.
At this point in time the "System" LED stays orange throughout.
Here bootvar has:
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x8002 (will be 0x2102 at next reload)
We also tried formatting disk0: but had following error:
error formatting disk0:
Also dir disk0: in Privileged mode had:
Error opening disk0:/ (No such device)
And show file has:
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     ro   flexwan-fpd:
             -             -      disk     rw   disk0:
*    512081920     152354816      disk     rw   sup-bootdisk:
     139030624             0    opaque     ro   sup-microcode:
             0     429763208    opaque     wo   sup-image:
        127212        127212     nvram     rw   const_nvram:
             -             -    opaque     rw   null:
             -             -    opaque     ro   tar:
             -             -   network     rw   tftp:
             -             -    opaque     wo   syslog:
       4059328       4057228     nvram     rw   nvram:
     512081920     512081920      disk     rw   bootdisk:#
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -    opaque     ro   cns:
    1024557056    1023590400      disk     rw   dfc#2-bootdisk:
     128229376     126119936      disk     rw   sip1-disk0:
Am I right here assuming that CF disk0: needs to be replaced?
Why is the router booting from rommon when there isn't any image on disk0:? does it boot from bootdisk: instead?
Apologies for a long post but I would be grateful if someone could help pointing out a way to bring this system back up and running.
Thanks for reading!!!
PS: Show version file is attached
8 Replies 8
Iulian Vaideanu
Level 4
Level 4
Most likely there is nothing in the disk0: slots - the RSPs have internal CF cards (sup-bootdisk and bootdisk, 512MB each) and the IOS images (at least two of them, judging by the amount of free space) are on sup-bootdisk.
I'd do this first (the fact that there are two RSPs might complicate things a bit, but let's assume for now that they contain the same information and behave the same way):
conf t
config-register 0x2102
boot system flash sup-bootdisk:c7600rsp72043-advipservices-mz.122-33.SRE5.bin
exit
wr mem
reload
Hi  Lulian,
Thank you for taking the time to reply.
show sup-bootdisk: suggests multiple files(please refer below). Is it advisable to delete unwanted files or should I proceed with boot system flash anyway?
 show sup-bootdisk: all ------------------
-#- --length-- -----date/time------ path
1    145916260 Feb 16 2012 22:30:02 +00:00 c7600rsp72043-advipservices-mz.122-33.SRE5.bin
2     33554432 Apr 3 2012 09:44:10 +00:00 sea_log.dat
3    179579820 Sep 24 2013 10:10:52 +00:00 c7600rsp72043-advipservicesk9-mz.153-1.S2.bin
4       489905 Jan 1 2000 00:14:16 +00:00 crashinfo_20000101-001417-UTC
152354816 bytes available (359727104 bytes used)
It's advisable to configure "boot system flash ..." so that you can be sure it boots the same IOS every time, no matter what other images you may add to or delete from flash in the future.  Deleting unnecessary files is optional (until you need the space to upload a newer image).
Thanks lulian.
I am afraid I can only check the commands that you suggested tomorrow. I will keep you posted.
Thanks again!
Hi lulian,
We followed your suggested commands:
conf t
exit
wr mem
reload
However after the reload, router jumped straight to rommon.
Now we are unable to bring it back from rommon even with confreg settings. It is stuck in rommon..
When in ROMMON, manual booting should be possible, with "boot sup-bootdisk:c7600rsp72043-advipservices-mz.122-33.SRE5.bin") (or "boot bootdisk:c7600rsp72043-advipservices-mz.122-33.SRE5.bin" - I'm not sure how the SP identifies its flash when in ROMMON).
Also, a console capture of the boot process would be helpful, to see why it doesn't go beyond ROMMON...
Hi lulian,
Apologies for the delayed reply as the permission to customer site was denied. Further to our issue, we opened a TAC and the only way we could solve this issue was by creating RMA and replacing both RSP 1 and RSP 2.
Supposedly there was some hardware bug.
Thank you again for your time and help.
Hi lulian,
conf t
exit
wr mem
reload
