7613 High CPU utilization
Samer Ghishan
Community Member
We have a Cisco 7613 router and we are using it to aggregate the customer on through ethernet and E1s. The CPU utilization reached 84 % since the last couple of weeks. Below is the " show proc cpu sorted" command.
CPU utilization for five seconds: 80%/62%; one minute: 75%; five minutes: 75%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
462   8974379402129299664        421 10.95% 12.86% 12.97%   0 PPP Events
196   2583163922560587415          0  4.79%  2.94%  2.72%   0 IP Input
  10    85066040 395965254        214  0.63%  0.52%  0.48%   0 ARP Input
494    14400404    667101      21586  0.47%  0.22%  0.21%   0 MFI LFD Stats Pr
417    19016200  93700037        202  0.23%  0.09%  0.08%   0 OSPF-100 Router
492     5042360   2414006       2088  0.15%  0.06%  0.06%   0 Tag Control
175     1557312  11981435        129  0.07%  0.00%  0.00%   0 esw_vlan_stat_pr
266    12123656  31468460        385  0.07%  0.15%  0.12%   0 IP RIB Update
332    19359304   8098769       2390  0.07%  0.08%  0.08%   0 HIDDEN VLAN Proc
  38     1681700  12622832        133  0.07%  0.00%  0.00%   0 EnvMon
  25     5926416  37994469        155  0.07%  0.01%  0.00%   0 IPC Seat Manager
198     7727228  88461084         87  0.07%  0.04%  0.01%   0 ADJ resolve proc
284     6642508  16428072        404  0.07%  0.04%  0.02%   0 IPC LC Message H
  13           0         1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  12           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  11       15220  16892514          0  0.00%  0.00%  0.00%   0 ARP Background
   7    48159076   3303297      14579  0.00%  0.18%  0.21%   0 Check heaps
   9           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8          12       104        115  0.00%  0.00%  0.00%   0 Pool Manager
  14           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  15           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  22        2544  16193096          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  16         108       514        210  0.00%  0.00%  0.00%   0 Entity MIB API
  24        1648  16193103          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  17      515384  16205021         31  0.00%  0.00%  0.00%   0 EEM ED Syslog
  18           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  27       32108   3239140          9  0.00%  0.00%  0.00%   0 IPC Loadometer
  19          36    269937          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  29           0         1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  20         564   3239111          0  0.00%  0.00%  0.00%   0 IPC Service NonC
  31           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  32         208     10650         19  0.00%  0.00%  0.00%   0 DDR Timers
  21          12        92        130  0.00%  0.00%  0.00%   0 PF_Split Sync Pr
  34           0         1          0  0.00%  0.00%  0.00%   0 SENSOR-MGR event
  23       46320  73892193          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  36           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  37           0         1          0  0.00%  0.00%  0.00%   0 Exception contro
  26        5864     23052        254  0.00%  0.00%  0.00%   0 IPC Seat Control
  39        1860  16193067          0  0.00%  0.00%  0.00%   0 GraphIt
  40         148      1707         86  0.00%  0.00%  0.00%   0 rf proxy rp agen
  41          76       633        120  0.00%  0.00%  0.00%   0 rf proxy message
  42          56       354        158  0.00%  0.00%  0.00%   0 Entity MIB C6k P
  43           0         3          0  0.00%  0.00%  0.00%   0 client_entity_se
  44           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  28           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  46           8       144         55  0.00%  0.00%  0.00%   0 Cat6k SNMP
  47        2552     52929         48  0.00%  0.00%  0.00%   0 Cat6k SNMP Trap
  30         104   1619602          0  0.00%  0.00%  0.00%   0 Compute SRP rate
  49           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
   6           0         1          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
  51          12       259         46  0.00%  0.00%  0.00%   0 IDB Work
  52      118564  29227057          4  0.00%  0.00%  0.00%   0 Logger
  33           0        10          0  0.00%  0.00%  0.00%   0 ifIndex Receive
  54      198892  17640814         11  0.00%  0.00%  0.00%   0 Per-Second Jobs
  55     4359588    310322      14048  0.00%  0.02%  0.00%   0 Per-minute Jobs
  56         792     13746         57  0.00%  0.00%  0.00%   0 IF-MGR control p
  57         508    553902          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  35           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  59          40       941         42  0.00%  0.00%  0.00%   0 Env action
  60        1668  16193087          0  0.00%  0.00%  0.00%   0 EOBC ETSEC FREEZ
  61           0         2          0  0.00%  0.00%  0.00%   0 Flash ICC Server
  45           0         1          0  0.00%  0.00%  0.00%   0 Snmp ICC Process
   4           4       426          9  0.00%  0.00%  0.00%   0 Retransmission o
  64     2553496 142155332         17  0.00%  0.00%  0.00%   0 Net Input
  65           4        24        166  0.00%  0.00%  0.00%   0 draco-oir-proces
  66           0         6          0  0.00%  0.00%  0.00%   0 FR LMI
   3           8        34        235  0.00%  0.00%  0.00%   0 VTEMPLATE Backgr
  68           8        17        470  0.00%  0.00%  0.00%   0 HA_INCR_SYNC_PRO
  69     2884516  21659843        133  0.00%  0.00%  0.00%   0 IFCOM Msg Hdlr
  70           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
   2       61828   3239135         19  0.00%  0.00%  0.00%   0 Load Meter
  72        1472   4557393          0  0.00%  0.00%  0.00%   0 BGP Scheduler
  73           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  74           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  75           4        20        200  0.00%  0.00%  0.00%   0 OBFL Cfg Dispatc
  76       57340   8373659          6  0.00%  0.00%  0.00%   0 IP SLAs Sync Pro
  77           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  78           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  79           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  80           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  81      231772 748291146          0  0.00%  0.00%  0.00%   0 IP SLA Responder
  82           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  48        2568  16193095          0  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  84           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  85           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  86           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  87        1052   1079735          0  0.00%  0.00%  0.00%   0 SCP async: Draco
   5           4        11        363  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
  89           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  90           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  91           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  92           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  93           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  94           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  95           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  96           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  97           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  50       81332  16234879          5  0.00%  0.00%  0.00%   0 Net Background
  53        3024  16193061          0  0.00%  0.00%  0.00%   0 TTY Background
100           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
101           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
102           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
103           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
104           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
  58           0         7          0  0.00%  0.00%  0.00%   0 RPC rf_rfmib_not
106           0        11          0  0.00%  0.00%  0.00%   0 RPC Sync
107           0         3          0  0.00%  0.00%  0.00%   0 RPC rpc-slave-17
108           0         2          0  0.00%  0.00%  0.00%   0 SCP Multicast
109           0     26994          0  0.00%  0.00%  0.00%   0 simba
110           4         8        500  0.00%  0.00%  0.00%   0 MWAM CONFIG ON S
111           0         1          0  0.00%  0.00%  0.00%   0 SAMI CONFIG ON S
112           0         1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
113           0         8          0  0.00%  0.00%  0.00%   0 DHCPC HA
114           0         8          0  0.00%  0.00%  0.00%   0 DHCPD HA
115           0         1          0  0.00%  0.00%  0.00%   0 MDR SM Proxy Sla
   1          32       329         97  0.00%  0.00%  0.00%   0 Chunk Manager
117           0         3          0  0.00%  0.00%  0.00%   0 CWAN HA VLAN SYN
118           4        29        137  0.00%  0.00%  0.00%   0 CWAN IF EVENT HA
119           0         3          0  0.00%  0.00%  0.00%   0 CWAN APS HA Proc
120           0         3          0  0.00%  0.00%  0.00%   0 CWAN SRP HA Proc
121           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
122       62184  16189969          3  0.00%  0.00%  0.00%   0 Heartbeat Proces
  62           8        21        380  0.00%  0.00%  0.00%   0 ICC Nego
  63           0     27001          0  0.00%  0.00%  0.00%   0 itasca
125           0         1          0  0.00%  0.00%  0.00%   0 Const ICC except
  67       13360   1349966          9  0.00%  0.00%  0.00%   0 svclc
127      300232  27312172         10  0.00%  0.00%  0.00%   0 ICC Async mcast
128           0         1          0  0.00%  0.00%  0.00%   0 ICC_REQ Debug Pr
129           0         1          0  0.00%  0.00%  0.00%   0 ICC FC Process
130           0         1          0  0.00%  0.00%  0.00%   0 ICC FC Test Send
131           0         1          0  0.00%  0.00%  0.00%   0 ICC FC Test Low
132           0         1          0  0.00%  0.00%  0.00%   0 PF Sync process
  71        8060  63225798          0  0.00%  0.00%  0.00%   0 CCM Subscriber P
134           0         4          0  0.00%  0.00%  0.00%   0 CWRP SPA TSM HA
135           4         4       1000  0.00%  0.00%  0.00%   0 Switch IP Host T
136           0         1          0  0.00%  0.00%  0.00%   0 EM Action CNS
137           8        23        347  0.00%  0.00%  0.00%   0 PF_Init Process
138           0        28          0  0.00%  0.00%  0.00%   0 RPC pf-split-rp
139           4        28        142  0.00%  0.00%  0.00%   0 RPC idprom-MP
140        2540  10464681          0  0.00%  0.00%  0.00%   0 Transport Port A
141           0         1          0  0.00%  0.00%  0.00%   0 BACK CHECK
  83           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
143           0         8          0  0.00%  0.00%  0.00%   0 RFS server proce
144       79324   3299712         24  0.00%  0.00%  0.00%   0 Compute load avg
145          68       887         76  0.00%  0.00%  0.00%   0 CHKPT rcv MSG pr
146           0         2          0  0.00%  0.00%  0.00%   0 cpf_process_msg_
147      610728  12721085         48  0.00%  0.00%  0.00%   0 cpf_process_ipcQ
148           0        19          0  0.00%  0.00%  0.00%   0 IPC Apps Task
149     8996444 139866962         64  0.00%  0.03%  0.04%   0 IFCOM Msg Hdlr
150           0        28          0  0.00%  0.00%  0.00%   0 AggMgr Process
151           0         2          0  0.00%  0.00%  0.00%   0 CWAN ICC
152           0     27002          0  0.00%  0.00%  0.00%   0 SFF8472
153           0         1          0  0.00%  0.00%  0.00%   0 Remote Console P
154           0         1          0  0.00%  0.00%  0.00%   0 CCB SEND RETRY A
155           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
156       57036    737530         77  0.00%  0.00%  0.00%   0 CWAN OIR Handler
157           0         2          0  0.00%  0.00%  0.00%   0 CWAN Egress SACL
158           0         1          0  0.00%  0.00%  0.00%   0 DSX3MIB ll handl
159           4        15        266  0.00%  0.00%  0.00%   0 FPD Management P
160           0         1          0  0.00%  0.00%  0.00%   0 FPD Action Proce
161           0         2          0  0.00%  0.00%  0.00%   0 const FPD ICC pr
162           0         1          0  0.00%  0.00%  0.00%   0 dwdm RPC RP proc
163           0         2          0  0.00%  0.00%  0.00%   0 netclk_process
164           4         4       1000  0.00%  0.00%  0.00%   0 netclk_ha_proces
165           0         7          0  0.00%  0.00%  0.00%   0 SCP async: LCP#7
  88           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
167        3788    277108         13  0.00%  0.00%  0.00%   0 CMFI RP process
168        1980  16193083          0  0.00%  0.00%  0.00%   0 CWAN CHOCX PROCE
169     1187460   6538083        181  0.00%  0.00%  0.00%   0 HAL Mailbox
170        3000  16193084          0  0.00%  0.00%  0.00%   0 CWAN CHDSX PROCE
171           0         1          0  0.00%  0.00%  0.00%   0 CT3 Mailbox
172           0         1          0  0.00%  0.00%  0.00%   0 CE3 Mailbox
173           0         2          0  0.00%  0.00%  0.00%   0 MIP Mailbox
174           0         1          0  0.00%  0.00%  0.00%   0 Earl NDE Task
  98           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
176           0        10          0  0.00%  0.00%  0.00%   0 Gemini L3 forwar
177           0         1          0  0.00%  0.00%  0.00%   0 CWRP SPA ATM OIR
178       37128 504301944          0  0.00%  0.00%  0.00%   0 SPA CHOCX APS Pr
179           4         1       4000  0.00%  0.00%  0.00%   0 spa_plim_fsvr
180           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
181           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
182           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
183           0         1          0  0.00%  0.00%  0.00%   0 Async write proc
184          76    269937          0  0.00%  0.00%  0.00%   0 DFS flush period
185        2496     75217         33  0.00%  0.00%  0.00%   0 AAA Server
186           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
187       47644 505437006          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
188           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
189           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
190           0     53988          0  0.00%  0.00%  0.00%   0 IP Admin SM Proc
191           0        15          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
192           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
193          44    135025          0  0.00%  0.00%  0.00%   0 DHCP Snooping
194           0         2          0  0.00%  0.00%  0.00%   0 CEF switching ba
195        1204    541859          2  0.00%  0.00%  0.00%   0 IP ARP Adjacency
  99           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
197       20876  15263011          1  0.00%  0.00%  0.00%   0 ICMP event handl
105           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Version
199           0         1          0  0.00%  0.00%  0.00%   0 PPCP RP Stats Ba
200           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Echo event
201     1377024  10543075        130  0.00%  0.00%  0.00%   0 PPP SIP
202           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
203       14820     16020        925  0.00%  0.00%  0.00%   0 PPP IP Route
204      391240   5142228         76  0.00%  0.00%  0.00%   0 IP SLAs Sync Pro
205           0         3          0  0.00%  0.00%  0.00%   0 HDLC HA
206       81960   3221977         25  0.00%  0.00%  0.00%   0 ARP HA
207      909996  43478071         20  0.00%  0.00%  0.00%   0 Spanning Tree
208           4         5        800  0.00%  0.00%  0.00%   0 EAPoUDP Process
116       44044    269912        163  0.00%  0.00%  0.00%   0 RF CWAN HA Proce
210      482716   2999577        160  0.00%  0.00%  0.00%   0 SSS Manager
211           0         1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
212        3084    142329         21  0.00%  0.00%  0.00%   0 SSS Feature Mana
213        8684  63265246          0  0.00%  0.00%  0.00%   0 SSS Feature Time
214           0         1          0  0.00%  0.00%  0.00%   0 SG DPM
215           0         1          0  0.00%  0.00%  0.00%   0 Timer handler fo
216           0         1          0  0.00%  0.00%  0.00%   0 Prepaid response
217           0         1          0  0.00%  0.00%  0.00%   0 Timed Policy act
218           0         1          0  0.00%  0.00%  0.00%   0 AAA response han
219           0         1          0  0.00%  0.00%  0.00%   0 AAA EPD HANDLER
220           0         1          0  0.00%  0.00%  0.00%   0 PM EPD API
221           0         1          0  0.00%  0.00%  0.00%   0 AC Switch
222           0         2          0  0.00%  0.00%  0.00%   0 EFP Errd
223           0         1          0  0.00%  0.00%  0.00%   0 LSP Tunnel FRR
224           0         4          0  0.00%  0.00%  0.00%   0 MPLS Auto-Tunnel
225           0         1          0  0.00%  0.00%  0.00%   0 O-UNI Client Msg
226           0         3          0  0.00%  0.00%  0.00%   0 cv6 per prefix a
227       12756    998400         12  0.00%  0.00%  0.00%   0 CCM
228           0         3          0  0.00%  0.00%  0.00%   0 CCM IPC flow con
229           0      2994          0  0.00%  0.00%  0.00%   0 DMLP Counter
230           0         2          0  0.00%  0.00%  0.00%   0 802.1x Accountin
330       29700    595512         49  0.00%  0.00%  0.00%   0 Collection proce
331           0         5          0  0.00%  0.00%  0.00%   0 Const Rate Limit
209      158832   6660651         23  0.00%  0.00%  0.00%   0 SSM connection m
333           0         1          0  0.00%  0.00%  0.00%   0 FR XDR manager
334           0         1          0  0.00%  0.00%  0.00%   0 CWAN LTL manager
335         844   1756529          0  0.00%  0.00%  0.00%   0 CWAN-RP SCP Proc
336          12        32        375  0.00%  0.00%  0.00%   0 CWAN-RP SCP Inpu
337           0         4          0  0.00%  0.00%  0.00%   0 DHCP Snooping HA
338           0         2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
339          72       215        334  0.00%  0.00%  0.00%   0 IPHC RP Process
340           4       171         23  0.00%  0.00%  0.00%   0 L2TRACE SERVER
341           0         1          0  0.00%  0.00%  0.00%   0 MLSM-CC Process
342        1196    276422          4  0.00%  0.00%  0.00%   0 CWPA QoS
343           0         2          0  0.00%  0.00%  0.00%   0 Const TCAM Mgr R
344           0         2          0  0.00%  0.00%  0.00%   0 MWAM_CONSOLE Tim
345           0         1          0  0.00%  0.00%  0.00%   0 Container Proces
346         316   3954152          0  0.00%  0.00%  0.00%   0 IP SIP Process
347           0         2          0  0.00%  0.00%  0.00%   0 IP Inband Sessio
348           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
349        5180     75847         68  0.00%  0.00%  0.00%   0 LOCAL AAA
350           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
351           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
352     3236876  92848343         34  0.00%  0.01%  0.00%   0 OSPF-100 Hello
353           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
354           0         1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
355           4       205         19  0.00%  0.00%  0.00%   0 MPLS Auto Mesh P
356           0         1          0  0.00%  0.00%  0.00%   0  Laminar Icc Eve
357           0         2          0  0.00%  0.00%  0.00%   0 SLB Main CPU pro
358           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
359           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
360       10556   1068799          9  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
361           0        10          0  0.00%  0.00%  0.00%   0 EEM ED Resource
362           0        19          0  0.00%  0.00%  0.00%   0 EEM ED Track
363           0        25          0  0.00%  0.00%  0.00%   0 L3MM Process
364           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
365           0        12          0  0.00%  0.00%  0.00%   0 RPC aapi_rp
366          52      1125         46  0.00%  0.00%  0.00%   0 RPC capi_rp
367           0         3          0  0.00%  0.00%  0.00%   0 RPC chapi_rp
368          24       781         30  0.00%  0.00%  0.00%   0 RPC dot1x_aaa_rp
369           0         2          0  0.00%  0.00%  0.00%   0 RPC ether_oam_sp
370           0         2          0  0.00%  0.00%  0.00%   0 RPC epld_sp2rp
371           0         2          0  0.00%  0.00%  0.00%   0 RPC gvrp_sp2rp
372           8        74        108  0.00%  0.00%  0.00%   0 RPC idbman_sp2mp
373           0         1          0  0.00%  0.00%  0.00%   0 LC Registry Expo
374       86740   1978325         43  0.00%  0.00%  0.00%   0 RPC online_diag_
375           0        46          0  0.00%  0.00%  0.00%   0 RPC online_wan_d
376          92       156        589  0.00%  0.00%  0.00%   0 RPC pagp_switch_
377          92       693        132  0.00%  0.00%  0.00%   0 RPC pm_switch_sp
378           0         2          0  0.00%  0.00%  0.00%   0 RPC psecure_rp
379           0         2          0  0.00%  0.00%  0.00%   0 RPC pt_switch_sp
380          16       692         23  0.00%  0.00%  0.00%   0 RPC qnq_switch_s
381           0         2          0  0.00%  0.00%  0.00%   0 RPC rf_cli_sp2rp
382           0         1          0  0.00%  0.00%  0.00%   0 SONET Traps
383       15144 134793030          0  0.00%  0.00%  0.00%   0 FR Broadcast Out
384           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
385           0         2          0  0.00%  0.00%  0.00%   0 RPC snmp_notify
386           4        45         88  0.00%  0.00%  0.00%   0 RPC snmp_stackli
387           0         2          0  0.00%  0.00%  0.00%   0 RPC span_switch_
388         188      2047         91  0.00%  0.00%  0.00%   0 RPC stp_sp2mp_ap
389           0         1          0  0.00%  0.00%  0.00%   0 EIGRP-IPv4: Rout
390           0         2          0  0.00%  0.00%  0.00%   0 Module enable-di
391          16        45        355  0.00%  0.00%  0.00%   0 RPC c6k_power_rp
392           0        44          0  0.00%  0.00%  0.00%   0 RPC c6k_rp_envir
393           0         1          0  0.00%  0.00%  0.00%   0 CONST AFL
394           0         2          0  0.00%  0.00%  0.00%   0 RPC cwan_ltl_sp2
395         208   2696331          0  0.00%  0.00%  0.00%   0 RP Error Detecti
396           0         2          0  0.00%  0.00%  0.00%   0 RPC error_detect
397           0         1          0  0.00%  0.00%  0.00%   0 HW Capacity ICC
398           0         2          0  0.00%  0.00%  0.00%   0 RPC itasca_rp
399           0         1          0  0.00%  0.00%  0.00%   0 RP L2 Applicatio
400           0         8          0  0.00%  0.00%  0.00%   0 LACP-MP Process
401           0        36          0  0.00%  0.00%  0.00%   0 Online Diag EEM
402           0         8          0  0.00%  0.00%  0.00%   0 PAgP-MP Process
403           0         2          0  0.00%  0.00%  0.00%   0 RPC pclc_g2_agsm
404           4        17        235  0.00%  0.00%  0.00%   0 RPC pclc_g2_fw_r
405           8        61        131  0.00%  0.00%  0.00%   0 Logger ICC Proce
406           0        10          0  0.00%  0.00%  0.00%   0 RPC pf_issu_sp2r
407           0         2          0  0.00%  0.00%  0.00%   0 RPC pikachu_rp
408           0         2          0  0.00%  0.00%  0.00%   0 FR ARP
409         732      6107        119  0.00%  0.00%  0.00%   0 RPC pm-mp
410       40784  89666588          0  0.00%  0.00%  0.00%   0 PM Callback
411    56145644 547247522        102  0.00%  0.25%  0.24%   0 Port manager per
412         472   3239108          0  0.00%  0.00%  0.00%   0 Max CPU utilizat
413           0        16          0  0.00%  0.00%  0.00%   0 RPC lcc_sp
414           0         9          0  0.00%  0.00%  0.00%   0 RPC fabman_sp
415           0      4500          0  0.00%  0.00%  0.00%   0 rp to lc clock u
416      145900   1091962        133  0.00%  0.00%  0.00%   0 SPA ENTITY Proce
231           0        22          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
418           0         2          0  0.00%  0.00%  0.00%   0 SPAN Capture
419           0        14          0  0.00%  0.00%  0.00%   0 EC-Card-Cfg
420           0         2          0  0.00%  0.00%  0.00%   0 RPC sw_backup_in
421       16796    209750         80  0.00%  0.00%  0.00%   0 RPC sw_vlan_rp
422           0         4          0  0.00%  0.00%  0.00%   0 RPC udld_rp
423       13328    105062        126  0.00%  0.00%  0.00%   0 RPC vtp_const_ap
424           0         2          0  0.00%  0.00%  0.00%   0 RPC rep_sp2rp_ap
425           0         2          0  0.00%  0.00%  0.00%   0 RPC dot1ad_sp2mp
426           0         2          0  0.00%  0.00%  0.00%   0 Rommon upgrade p
427          60    269976          0  0.00%  0.00%  0.00%   0 Call Home Timer
428           4         5        800  0.00%  0.00%  0.00%   0 CWAN OIR IPC Rea
429           0      4499          0  0.00%  0.00%  0.00%   0 PF Clock Process
430           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
431           0         3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
432           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
433           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
434           0         3          0  0.00%  0.00%  0.00%   0 EEM ED None
435           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
436           0        11          0  0.00%  0.00%  0.00%   0 EEM ED RF
437           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
438          32    405772          0  0.00%  0.00%  0.00%   0 EEM ED Timer
439           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Test
440           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Config
441           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Env
442           0         2          0  0.00%  0.00%  0.00%   0 Call Home proces
443           0         1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
444           0         1          0  0.00%  0.00%  0.00%   0 IP SLA AutoEther
445         128    808857          0  0.00%  0.00%  0.00%   0 IP SLA MPLSLM Pr
446        3908    276358         14  0.00%  0.00%  0.00%   0 DRMI Config Disp
447      216500   1220568        177  0.00%  0.00%  0.00%   0 Syslog
448           4        20        200  0.00%  0.00%  0.00%   0 CWAN Bridge task
449           0         3          0  0.00%  0.00%  0.00%   0 QM MRM Process o
450         244       756        322  0.00%  0.00%  0.00%   0 QM Process on RP
451          24       268         89  0.00%  0.00%  0.00%   0 QM Reply Process
452           0         2          0  0.00%  0.00%  0.00%   0 QM Timer ACL Pro
453         144   1295816          0  0.00%  0.00%  0.00%   0 DHCP Snooping Sw
454        2600   3239099          0  0.00%  0.00%  0.00%   0 Track
455           0        21          0  0.00%  0.00%  0.00%   0 CONST PC POLICYM
456           0         1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
457           0         1          0  0.00%  0.00%  0.00%   0 Online Diag CNS
458          20    269937          0  0.00%  0.00%  0.00%   0 VACL Logger
459           0        11          0  0.00%  0.00%  0.00%   0 REP RP Proc
460           0         2          0  0.00%  0.00%  0.00%   0 SIP10G QM Proces
461       78956 505435229          0  0.00%  0.00%  0.00%   0 PPP manager
246         748      5206        143  0.00%  0.00%  0.00%   0 HWIF QoS Process
463       18836  16194066          1  0.00%  0.00%  0.00%   0 Multilink PPP
464          52      5834          8  0.00%  0.00%  0.00%   0 Multilink event
465          16    224926          0  0.00%  0.00%  0.00%   0 FR FRAGMENTATION
466      1499002021680101          0  0.00%  0.00%  0.00%   0 IP SLAs Event Pr
467          24       377         63  0.00%  0.00%  0.00%   0 Kron Process
468    16103552 195012892         82  0.00%  0.11%  0.05%   0 IP SNMP
469     4469844 100146655         44  0.00%  0.01%  0.00%   0 PDU DISPATCHER
470    24507380 103031899        237  0.00%  0.13%  0.07%   0 SNMP ENGINE
471           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
472           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
473           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
474         604    674773          0  0.00%  0.00%  0.00%   0 FR TUNNEL
475           0       175          0  0.00%  0.00%  0.00%   0 RSVP
476           0         1          0  0.00%  0.00%  0.00%   0 FRF9 manager
477           0         1          0  0.00%  0.00%  0.00%   0 FRF9 timed event
478        2248   2159465          1  0.00%  0.00%  0.00%   0 SCP async: Draco
479          68   1349536          0  0.00%  0.00%  0.00%   0 compute load per
480      402924   3833922        105  0.00%  0.00%  0.00%   0 LDP
481      610560   6534577         93  0.00%  0.00%  0.00%   0 IP SLAs Sync Pro
482      270776   3421106         79  0.00%  0.00%  0.00%   0 IP SLAs Sync Pro
483      104060   7524408         13  0.00%  0.00%  0.00%   0 IP SLAs Sync Pro
484         440    316533          1  0.00%  0.00%  0.00%   0 SCP async: Draco
485      999588  15730539         63  0.00%  0.00%  0.00%   0 IFCOM Msg Hdlr
486      809420  22421252         36  0.00%  0.00%  0.00%   0 BGP Router
487        3908    167221         23  0.00%  0.00%  0.00%   0 BGP I/O
488      355644     85887       4140  0.00%  0.00%  0.00%   0 BGP Scanner
489           0        79          0  0.00%  0.00%  0.00%   0 BGP Event
490           4         6        666  0.00%  0.00%  0.00%   0 TCP Listener
491        1484    934268          1  0.00%  0.00%  0.00%   0 LSD Main Proc
247           0         3          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
493        4940     77804         63  0.00%  0.00%  0.00%   0 IPRM
252           0         1          0  0.00%  0.00%  0.00%   0 Switch IP Admiss
495         104    311210          0  0.00%  0.00%  0.00%   0 MFI LFD Timer Pr
496           4         2       2000  0.00%  0.00%  0.00%   0 MFI LFD Main Pro
497         820     20962         39  0.00%  0.00%  0.00%   0 Tagcon Addr
499         144       193        746  0.00%  0.06%  0.01%   1 Virtual Exec
500       60724   2129416         28  0.00%  0.00%  0.00%   0 TDP Hello
501         684   2303045          0  0.00%  0.00%  0.00%   0 MPLS HC Counter
502        1380         7     197142  0.00%  0.00%  0.00%   0 IPRM Collection
503           0         1          0  0.00%  0.00%  0.00%   0 LSP Verification
504        2324     77698         29  0.00%  0.00%  0.00%   0 LDP Background
7 Replies 7
Reza Sharifi
what version of IOS are you running?
we are running this version
c7600rsp72043-advipservices-mz.122-33.SRD4.bin
Peter Paluch
Samer,
According to the output, your router is currently high in the interrupt level CPU load. That can be caused by several reasons - please have a look at this document which deals with these issues in more detail:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
I am sorry for being unable to guide you more here as I have almost no experiences with these high-end devices. Still, this document could be a good start.
Best regards,
Peter
Giuseppe Larosa
Hello Samer,
your device is processing a lot of traffic on the main cpu
see:
CPU utilization for five seconds: 80%>>>62%<<<<; one minute: 75%; five minutes: 75%
most of cpu usage is caused by interrupts ( 62%) and 13% is used by PPP
see
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml
and
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml#utilities
and troubleshooting high cpu usage caused by interrupts
Are you using forms of multilink PPP over the E1 links?
the system should not allow to configure bundles of E1 that are in different PAs or different SPAs
Hope to help
Giuseppe
andtoth
Level 9
Level 9
The device is utilizing the CPU due to interrupts which usually means packets are being software switched by the CPU.
Have a look at the following documentation which was originally written for 6500 switches but since they are similar with 7600 platform, it should give you some useful ideas.
Catalyst 6500/6000 Switch High CPU Utilization
Also, try to think of recent changes in the configuration which might have caused the increase in the CPU utilization and try matching them with the exceptions mentioned in the documentation when a packet needs special processing.
If you cannot solve the issue following the documentation, you might want to consider opening a TAC case so that an engineer can have a closer look and assist you in finding the root cause of the problem.
Best regards,
Andras
andtoth
Level 9
Level 9
Sorry, double post.
andtoth
Level 9
Level 9
Sorry, double post.
