7k Upgrade Path from 4.2 to 5.1.3
katyialobue
7k Upgrade Path from 4.2 to 5.1.3:
I'm trying to confirm if I definately need to upgrade from 4.2 to 4.6/5.0 before I go to 5.1.3 for system and kickstart?
And then for EPLD, I see a few hops in the path, can I upgrade straight from 4.2 to 5.1?
Thank you in advance.
Roman Rodichev
Level 7
Level 7
You can upgrade straight from 4.2 to 5.1.3
EPLDs will be upgraded during the installation
The following EPLDs have changed
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/epld/epld_rn_5.2.html#wp147525
Great, thank you.
I thought eplds weren't upgraded without triggering the command? Or will it reject the upgrade?
On the off chance you happen to know, how long 2 sups and 6 cards will take with such a big jump and the epld upgrade? I'm thinking 30 mins a card ...
you are correct, I don't mean that they will be upgraded automatically, you have to upgrate them
30 minutes per switch should be enough time
