802.1p priority
jemekeren
hello all. does 802.1p only exist at 802.1q trunk. does it work over isl trunk link..? tx
Amit Singh
802.1p Exist both on ISl and 802.1Q trunks. ISl uses 1 byte user field in its 26 byte header that it attaches to an ethernet frame and out of that 1byte field 3 bytes are used for COS i.e 801.P priority.
HTH,please rate if it does.
-amit singh
