802.1x Authentication Fails on GB Switch but Works on Fast Ethernet Switch
james_fisk
This is my first post. We have fa and gi switches. 802.1x authentication works great on a fast Ethernet C2960 with firmware 12.2(55) SE. But clients fail to authenticate on a C3750 with firmware 12.2 (55)SE. The client PC has a GPO to enable the proper local configuration. A test notebook authenticates when connected to a the C2960 but fails on the C3750. I am wondering if there is an additional or different command required to configure a Gi switch. I would assume not because they are running the same firmware but the only difference is the hardware. I used command dot1x port-control auto to enable.
Thank you,
Jim
austinmbailey1
What commands are you running on the access ports?
On my Gigabit switches, we run the following commands:
dot1x max-req 3
dot1x max-reauth-req 3
authentication port-control autoauthentication timer reauthenticate 3600 (this is one hour, which should be default)
-Austin
Austin,
Thank you for your response. The port is question has the following configuration....
switchport access vlan xx
switchport mode access
dot1x pae authenicator
spanning-tree portfast
Try adding the following to access ports:
dot1x max-req 3
dot1x reauthentication
Do you have all of your radius commands set up the same as the other switch?
Glenn Martin
moving post to the Network Infrastructure>Lan Switching Community.
