802.1x printer authentication
JakubMalik1782
Frequent Visitor
Frequent Visitor
I have on my access switches (WS-C2960X-48LPD-L ) configured 802.1x authentication, but printers are authenticated over MAB and I would like authentication over certificate or username.
this is how the 802.1x settings on printers looks:
This is the configuration of ports on the switch:
switchport access vlan 803
switchport mode access
switchport nonegotiate
switchport voice vlan 20
authentication host-mode multi-domain
authentication order dot1x mab webauth
authentication priority dot1x mab webauth
authentication port-control auto
authentication violation replace
authentication fallback WEB_AUTH_PROFILE
mab
dot1x pae authenticator
dot1x timeout tx-period 2
dot1x max-req 10
spanning-tree portfast
Is it possible ? Have anyone experience with 802.1x on printers ?
Mark Elsen
 - In most cases this will not be possible because printers usually don't have supplicants which can provide the data you want them to authorize with. There may be brands  which can do this, I do not know of any of them myself.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
It is Konica bizhub bizhub c364 and bizhub 4750
 - This is another one I found through Google :
                    http://h10032.www1.hp.com/ctg/Manual/c00731218
 M.
