802.1x Problem
Sebastian Helmer
Level 10
Level 10
Dear all,
I configured 802.1x with an 2950 and IAS ins the LAB, everything is working finde with dynamic VLAN Assignement and Guest VLAN.
I did the same with an 2948, I need to use it (mangement decission they don't want buy new one)
But there I got the error message:
A malformed RADIUS message was received from client 10.1.2.100. The data is the RADIUS message.
Can somebody helps me?
I think it must ne a setting in the IAS Radius-Client settin, or I'M wrong? I tried Cisco o. Radius Standard.
Thansk, Sebastian
mattkaya56
Level 2
Level 2
Can you post the configuration please.
When you say client do you mean PC or radius client?
I have seen this error when you use Windows client.
Hi mathew,
You will attached find my config and the eventlog message of the IAS.
thanks..
Sebastian
Sebastian Helmer
Level 10
Level 10
It is working now with Software 8.4. In my case i had trouble with 8.3..
Thanks all
