850 Booting Up Switch: (mode)
waqas.arshad
I am trying to boot the image from usb. But i am getting following error. Please help.
switch: boot usbflash0:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
Reading full image into memory.....................................................................................................................................................................................................................................................................................................done
Bundle Image
Kernel Address    : 0x5344e274
Kernel Size       : 0x41852f/4293935
Initramfs Address : 0x538667a4
Initramfs Size    : 0xe7766d/15169133
Compression Format: .mzip
Bootable image at @ ram:0x5344e274
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
File "usbflash0:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin" uncompressed and installed, entry point: 0x8166a600
Loading Linux kernel with entry point 0x8166a600 ...
Bootloader: Done loading app on core_mask: 0x3f
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
Feb 5 17:14:06 %PLATFORM_MGR-1-PLATMGR_INIT_FAIL: Platform ManagFeb 5 17:14:06 %IOSXE-2-PLATFORM: process ng_dumper: Process platform_mgr: terminated abnormally.
Feb 5 17:14:07 %IOSXE-2-PLATFORM: process platform_mgr: ===================== Exception Data ====================
Feb 5 17:14:07 %IOSXE-2-PLATFORM: process platform_mgr: Exception in 'platform_mgr' with Signal=SIGABRT(6)
Feb 5 17:14:07 %IOSXE-2-PLATFORM: process platform_mgr: Frame Pointer=0x7F931EC0, Program Counter=0x2C24B3B0
Feb 5 17:14:07 %IOSXE-2-PLATFORM: process platform_mgr: Thread ID=5542: -Traceback= 1#488249e9d04d3bc04e066fb31efe7654 pthread:2C239000+123B0
<Mon Feb  5 17:14:06 2018> Message from sysmgr: Reason Code:[2] Reset Reason:Service [platform_mgr] pid:[5542] terminated abnormally [6].
Service: platform_mgr
Description: 3K Platform Manager
Executable: /tmp/sw/mount/cat3k_caa-platform.SPA.03.06.06E.pkg//usr/binos/bin/platform_mgr
Started at Mon Feb  5 17:14:05 2018 (96264 us)
Stopped at Mon Feb  5 17:14:06 2018 (715249 us)
Uptime: 1 seconds
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 0.00 secs ago
PID: 5542
Exit code: signal 6
CWD: /var/sysmgr/work
PID: 5542
UUID: 3008
There is no defined storage or not enough space available to save the crash file.
Free storage space needed is 938128 bytes
Context registers for process 'platform_mgr'
====== signr 6
======= Process
PID=5542   PPPID=5273   PGRP=5542
Time: User=72   System=8
======= current - pid 5542
====== Registers
cp0_status = 0x0000000000008CF3  hi = 0x00000000000000BA
lo = 0x0000000000080866
cp0_badvaddr = 0x000000002B4A15F8  cp0_cause = 0x0000000000800020
cp0_epc =  0x000000002C24B3B0
mpl[0] = 0x0000000000000000  mpl[1] = 0x0000000000000000
mpl[2] =  0x0000000000000000
mtp[0] = 0x0000000000000000  mtp[1] = 0x0000000000000000
mtp[2] =  0x0000000000000000
R0  0x0000000000000000  R1  0x0000000010008CE1
R2  0x0000000000000000  R3  0x000000002D806420
R4  0x00000000000015A6  R5  0x00000000000015A6
R6  0x0000000000000006  R7  0x0000000000000000
R8  0x0000000000000006  R9  0x000000002C268020
R10 0xFFFFFFFFFEFEFEFF  R11 0xFFFFFFFFFEFEFEFF
R12 0xFFFFFFFFFFFFFF6E  R13 0x0000000000000000
R14 0xC000000000000000  R15 0x78020000FFFFFFFF
R16 0x0000000055453760  R17 0x000000004E470000
R18 0x000000000000002A  R19 0x000000000000002A
R20 0x000000005544D064  R21 0x000000005544D498
R22 0x0000000000000000  R23 0x000000005544D494
R24 0xFFFFFFFFF0000000  R25 0x000000002C24B370
R26 0xFFFFFFFFFBAD2A84  R27 0x0000000000000000
R28 0x0000000055453760  R29 0x000000007F931EC0
R30 0x0000000000000000  R31 0x0000000055399E24
get_local: failed: No such file or directory
Unmounting ng3k filesystems...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Please stand by while rebooting the system...
Restarting system.
Booting...
Interface GE 0 link down***ERROR: PHY link is down
flash:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin: no such file or directory
Cannot open file flash:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
The system is unable to boot automatically. The
BOOT environment variable needs to be set to a
bootable image.
switch: ?
           ? -- Present list of available commands
         arp -- Show arp table or arp-resolve an address
        boot -- Load and boot an executable image
         cat -- Concatenate (type) file(s)
        copy -- Copy a file
      delete -- Delete file(s)
         dir -- List files in directories
emergency-install -- Initiate Disaster Recovery
  flash_init -- Initialize filesystem(s)
      format -- Format a filesystem
        fsck -- Check filesystem consistency
        help -- Present list of available commands
   mgmt_init -- initialize management port
       mkdir -- Create dir(s)
        more -- Concatenate (display) file(s)
        ping -- Send ICMP ECHO_REQUEST packets to a network host
     readrtc -- Read RTC
      rename -- Rename a file
       reset -- Reset the system
       rmdir -- Delete empty dir(s)
         set -- Set or display environment variables
      set_bs -- Set attributes on a boot sector filesystem
   set_param -- Set system parameters in flash
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
    writertc -- Write RTC
switch: config t
Unknown cmd: config
switch:
CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 4.68, RELEASE SOFTWARE (P)
Compiled Fri Aug 25 16:01:01 PDT 2017 by rel
switch:
switch: boot system ?
system: no such device
Cannot open file system
Error loading "system"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch: boot usb0
usb0: no such device
Cannot open file usb0
Error loading "usb0"
switch:
usbflash0:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin: no such device
Cannot open file usbflash0:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
Error loading "usbflash0:cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin"
switch: boot ?
?: no such device
Cannot open file ?
?: no such device
?: no such device
Leo Laohoo
This could be CSCva30394.
While in ROMmon, post the complete output to the command "dir flash:".
Hi Leo,
Here is the output of Dir Flash:
switch: dir flash:
Directory of flash:/
32065  drwx  4096       .
     2  drwx  4096       ..
32066  -rw-  2097152    nvram_config
32067  -rw-  15954556   cat3k_caa-guestshell.16.03.05b.SPA.pkg
32068  -rw-  22301472   cat3k_caa-rpbase.16.03.05b.SPA.pkg
32069  -rw-  266035828  cat3k_caa-rpcore.16.03.05b.SPA.pkg
96193  -rw-  9089660    cat3k_caa-srdriver.16.03.05b.SPA.pkg
96194  -rw-  212812400  cat3k_caa-wcm.16.03.05b.SPA.pkg
112225  -rw-  13423224   cat3k_caa-webui.16.03.05b.SPA.pkg
112226  -rw-  4748       packages.conf
112227  -rw-  185        bootloader_evt_handle.log
48097  drwx  4096       core
56113  drwx  4096       .prst_sync
72145  drwx  4096       .rollback_timer
80161  drwx  4096       dc_profile_dir
80163  drwx  4096       gs_script
112228  -rw-  65301      memleak.tcl
112229  -rw-  76         boothelper.log
88177  drwx  4096       .installer
112230  -rw-  2097152    nvram_config_bkup
112231  -rw-  34         pnp-tech-time
112232  -rw-  45206      pnp-tech-discovery-summary
112233  -rw-  556        vlan.dat
112234  -rw-  303772864  cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
2505953280 bytes available (908537856 bytes used)
switch: ?
         arp -- Show arp table or arp-resolve an address. -f to flush
        copy -- Copy a file
         dig -- Lookup a name via a remote dns server
        mlog -- In-memory log control
   net-debug -- Show/change network debug val
    net-dhcp -- Initiate DHCP request for remote configuration
    net-show -- Show network parameters
net-tcp-bufs -- see/set tcp number of  buffers
net-tcp-mss -- see/set tcp mss
   net6-dhcp -- test dhcpv6
   net6-show -- Display ipv6 info
       ping4 -- Send ICMP ECHO_REQUEST packets to a network host
       ping6 -- Ping v6 host
     readrtc -- Read RTC
