857w router help
glen-c999
Hi all,
I've just picked up a new Cisco 857w router and I'm having some diffuculty setting it up.
As far as I understand the device ships with minimal configuration already present.
I am able to connect via console and have access to the IOS.
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(6)T10, RELEASE SOFTWARE (fc4)
I'm having trouble with DHCP.  According to the documentation it shipped with it is configured as a DHCP server but it doesn't seem to be issuing IP addresses on its ethernet ports.
I have enabled the ports (no shutdown on those interfaces)
The green LED on eth 1 lights up when I connect a cable to my laptop
The laptop is configured to have an IP address assigned automatically by the DHCP server for its wired ethernet port.
So, the question is, Do I need to configure the router as a DHCP server?  I am trying to find its IP address so I can connect to the GUI.
Also, theres a clicking/switching sound coming from it at regular intervals roughly once a minute, is this normal?
27 Replies 27
I don't see  why we should use a bvi here as the interface vlan is playing this role for all ports on the switch module.
Regards.
Alain
- There is a BVI configured on that router and VLAN 1.
- So bridge route command is used to enable routing of protocols within a bridge group in this case "1"
Hi Guys,  I wont have access to the router until thursday,  I'll post again then.  Thanks for the help so far!
Hi again,
I've disabled the BVI as its not needed at this point.
This is what Ive got, as you can see still no IP being assigned to fa1
(config-if)#do show run interface fastethernet1
Building configuration...
Current configuration : 82 bytes
interface FastEthernet1
ip dhcp client update dns
spanning-tree portfast
end
cwr(config-if)#do show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES TFTP   administratively down down
Dot11Radio0.1              unassigned      YES unset  administratively down down
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
ATM0                       unassigned      YES NVRAM  initializing          down
Vlan1                      192.168.1.1     YES NVRAM  up                    up
Loopback0                  192.169.3.1     YES NVRAM  up                    up
BVI1                       unassigned      YES NVRAM  administratively down down
Virtual-Dot11Radio0        unassigned      YES TFTP   administratively down down
Virtual-Dot11Radio0.1      unassigned      YES unset  administratively down down
this interface is supposed to be a L2 interface so this is the vlan 1 interface which routes and it is up/up with an IP address so you can't still get an IP address on a PC connected into this f1 port ?
Regards.
Alain.
Can you post your full config please?
Hi Mohammad,
After much more messing around I decided to remove its config and start again.  I thought I'd try the SDM v2.5 to try access the router but no luck there either.
The GUI installation process is unable to access the router.  I followed the instructions on the help page which gave it a basic config to get started as you can see below.  If I can get the GUI to at least see the router I should be ok to get some progress.
Current configuration : 2592 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
crypto pki trustpoint TP-self-signed-2049616826
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2049616826
revocation-check none
rsakeypair TP-self-signed-2049616826
crypto pki certificate chain TP-self-signed-2049616826
certificate self-signed 01
3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32303439 36313638 3236301E 170D3131 31313131 31343233
34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30343936
31363832 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100BB8A 1F0E9A22 ABF1C58D 74782127 AAE4E8C7 6F4E31DD 8560C730 B2A1F61E
64C2499D 96229323 3CB452DC CB449778 0B37C5A4 9FCD1E4A D2AE9C24 85DCE982
1D5B342F 6F881FBF 059A2209 8BF70342 DC24278A 9B210AE7 E76D2B3C 811542B4
A8AC8359 BCB7EEEE 3F976782 AFA3556A 52FCC984 79DB003F 03C09C8B FFA7DE6E
B4E30203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
551D1104 0A300882 06526F75 74657230 1F060355 1D230418 30168014 43FA8C87
E54747CD 999EEF01 1FDA7532 DD512145 301D0603 551D0E04 16041443 FA8C87E5
4747CD99 9EEF011F DA7532DD 51214530 0D06092A 864886F7 0D010104 05000381
8100A626 05182450 8D4DC632 F957EBF0 94997260 F5CF0B49 88E1AE7E AAE1D1C2
DDC56F2E DDD87EE3 70631F84 CA79BA10 46170377 FA5DCA5A 2703530D 7950CED6
AEDB2842 BB323375 CB5D67D8 1CDB1998 A64661E4 2B3EE7CC 5CD7A9D0 3041537A
9AB52109 51A716B6 DFE0556A DF595FCA C254726A 5E500795 B882AC2F 37DB32BE EAFA
quit
username admin privilege 15 password 0 xxxxx
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
You have no IP address assigned so you can't communicate with the router.
Put an IP address under Vlan 1 interface and then you can try out SDM.
Regards.
Alain
Ok here you go, try this other than your usual general settings:
conf t
service dhcp
ip dhcp pool DHCP-POOL (or whatever you want to call it)
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
domain-name "whatever domain you want"
ip dhcp excluded-address 192.168.1.1 192.168.1.xxx
bridge irb
interface vlan 1
bridge-group 1
no shut
interface BVI1
ip address 192.168.1.1 255.255.255.0 (or whatever you want)
no shut
interface range fa0-3
no shut
ip classless (incase this is not already there)
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx (this would be your gateway)
bridge 1 protocol ieee
bridge 1 route ip
ip http server (this should enable the http server
Another way you can do it is like this:
conf t
service dhcp
ip cef
interface fa4
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx (This would be your WAN information)
ip nat outside
interface vlan 1
ip nat inside
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx (default gateway)
ip http server (or)
ip http secure server
this is just a basic config and then ofcourse you have to do other stuff like setup NAT, ACL's VTY, AAA etc.  Let me know if you have any questions.
glen-c999
Hi Mohammad,
Good news, I've finally managed to get it working.
After I removed the config completely.
I configured VLAN1 and DHCP as per the second post in this thread and router finally assigned a IP addresses to its ethernet ports.  Ive also installed the SDM now.  Oddly enough, the clicking sound has now also stopped!
Just one last question, the SDM seems to be quite slow via HTTP, is this normal?
Cool congratulations.  Not sure about the SDM I have never used it.
Try this:
ip http timeout-policy idle 600 life 86400 requests 10000
Regards.
Alain
Thanks Alain, I'll try that.
