871 and vlan priority
bataviaphil
Community Member
I have an 871, I would like to know if after I setup another vlan if I can give that vlan priority? I would like to hook up my Vonage up to that vlan. If anyone know or can point me to the right documents that would be a big help.
Giuseppe Larosa
Hello Phil,
if I understood correcly you would like to give priority to traffic originated in one vlan.
the QoS tools can provide a better treatment to the traffic originated in one vlan over the WAN link
you need to use class-maps to define traffic types
example
let's suppose the ip subnet associated to the vlan you want to be treated better is 192.168.11.0/24
access-list 11 permit 192.168.11.0 0.0.0.255
class-map preferred_traffic
match access-group 11
policy-map wan_cbwfq
class preferred_traffic
bandwidth percent 60
this has to be applied to wan interface with
int type x/y
service-policy out wan_cbwfq
see
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/config_wfq_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1041636
Hope to help
Giuseppe
Thank you I will give this a try. We do a lot of downloading and I would like the Vonage to take priority over everything else on the network. Do you think that putting it on its own vlan is a good idea?
adamclarkuk_2
Level 9
Level 9
I'm not sure what you mean 'given the vlan priority, can you explain what you need to happen?
