871 stops working (part 2)
sebastiasebas
Guess this is continuation of
>>>  https://supportforums.cisco.com/message/3339646#3339646
but as it was marked as "ended" ... I want to open a new one.
My Cisco 871w still stops working once a week.
Today I found it frozen, after the weekend, and I have executed few commands from the HyperTerminal ...
The commands were given by cisco coleagues in previous post :
show log
show ip int brief
show interfaces counters errors
show interface  FastEthernet1
show interface  FastEthernet1  stat
show interface  FastEthernet1  summary
show interface  FastEthernet1  switching
Here are the ouptut of the commands :
871-403#show log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 38 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 38 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: level informational, 41 message lines logged
Log Buffer (4096 bytes):
*Mar  1 00:00:13.721: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Mar  1 00:00:13.729: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Mar  1 00:00:15.345: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:15.345: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
*Mar  1 00:00:16.346: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:16.346: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
*Mar  1 00:00:18.150: USB init complete.
*Mar  1 00:00:41.493: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:41.901: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:42.265: %SYS-5-CONFIG_I: Configured from memory by console
*Oct  4 09:19:26.572: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Oct  4 09:19:26.620: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct  4 09:19:27.740: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(24)T5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Fri 04-Mar-11 07:45 by prod_rel_team
*Oct  4 09:19:27.740: %SNMP-5-COLDSTART: SNMP agent on host 871-403 is undergoing a cold start
*Oct  4 09:19:27.784: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Oct  4 09:19:27.976: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Oct  4 09:19:27.976: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Oct  4 09:19:27.996: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to up
*Oct  4 09:19:27.996: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
*Oct  4 09:19:27.996: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*Oct  4 09:19:27.996: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Oct  4 09:19:29.048: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to down
*Oct  4 09:19:29.048: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to down
*Oct  4 09:19:29.048: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to down
*Oct  4 09:19:29.048: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Oct  4 09:19:30.192: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to down
*Oct  4 09:19:31.376: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*Oct  4 09:19:32.368: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*Oct  4 09:19:33.368: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to up
*Oct  4 09:23:36.347: %CRYPTO-4-IKMP_NO_SA: IKE message from 195.212.29.180 has no SA and is not an initialization offer
*Oct  4 09:24:41.347: %CRYPTO-4-IKMP_NO_SA: IKE message from 195.212.29.180 has no SA and is not an initialization offer
*Oct  4 09:29:00.604: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Oct  4 09:44:17.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Oct  4 09:44:36.266: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Oct  4 10:10:24.370: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Oct  4 10:10:40.216: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Oct  4 10:18:12.833: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
871-403#
871-403#show ip int brief
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              213.229.144.194 YES NVRAM  up                    up
NVI0                       213.229.144.194 YES unset  up                    up
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Access2            unassigned      NO  TFTP   down                  down
Virtual-Template2          213.229.144.194 YES TFTP   down                  down
Vlan1                      192.168.78.2    YES NVRAM  up                    up
871-403#
871-403#show interfaces counters errors
Port        Align-Err    FCS-Err   Xmit-Err    Rcv-Err UnderSize
Fa0                 0          0          0          0         0
Fa1                 0          0         46          0         0
Fa2                 0          0          0          0         0
Fa3                 0          0          0          0         0
Port      Single-Col Multi-Col  Late-Col Excess-Col Carri-Sen     Runts    Giants
Fa0                0         0         0          0         1         0         0
Fa1           657829         0         0          0         1         0         0
Fa2                0         0         0          0         1         0         0
Fa3                0         0         0          0         1         0         0
871-403#
So it looks clear to me that it is "Fa1" the interface with problems .....
So I did few displays of this interface :
871-403#show interface  FastEthernet1
FastEthernet1 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0025.45e6.6864 (bia 0025.45e6.6864)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s
  Last input 2d07h, output never, output hang never
  Input queue: 0/75/701102/0 (size/max/drops/flushes); Total output drops: 845
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3000 bits/sec, 3 packets/sec
     4610237 packets input, 689162207 bytes, 0 no buffer
     Received 345885 broadcasts, 0 runts, 0 giants, 0 throttles
     4515734 packets output, 737766279 bytes, 0 underruns
     46 output errors, 657829 collisions, 2 interface resets
     550 unknown protocol drops
     0 lost carrier, 0 no carrier
871-403#
871-403#show interface  FastEthernet1  stat
FastEthernet1
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor    4611368  689311572    4515734  737766279
             Route cache          0          0          0          0
                   Total    4611368  689311572    4515734  737766279
871-403#show interface  FastEthernet1  summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* FastEthernet1            0 702713    0   845  3000    3     0    0    0
871-403#
871-403#show interface  FastEthernet1  switching
FastEthernet1
          Throttle count          0
                   Drops         RP     702901         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs          0      Drops          0
Well ... I would like to know ...
*) what is "IQD: pkts dropped from input queue" ..... "702.901"
*) what could be the reason for "IQD: pkts dropped from input queue" .....    "702.713"
*) any reason for "46 output errors, 657829 collisions, 2 interface resets ... 550 unknown protocol drops"
Your opinions are welcome !
Sebastian.
Florin Barhala
Level 6
Level 6
I would quit using Fa1 (administratively SHUT) and see what happens.
mr Florin - you mean
a) "Fa1" is already shut down now and that's the reason I have to use another ?
b) you want me to shut "Fa1" and never use it anymore ?
That interface works for 1 week .. then blocks.
I stop Cisco 871w, wait 10 seconds, start it again ... and it works perfect for another week or two.
It does not look to me as a "interface" problem ...
But I will try .... jejeje
Thanks.
Were you able to figure out the cause of the failure?  I am experiencing the same thing on my 871W running 15.1.4M4 which is the latest IOS version available.  It happens about every week for me too so I can collect data if there are more suggestions about what to collect and look at.
The closest thing I've been able to find is already fixed in my IOS version
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsi03915
