06-07-2013 08:21 AM - last edited on 03-25-2019 04:24 PM by ciscomoderator
I have a 871 unit and I can't figure out how to get access to the FA4 port. I have given it an IP address but I still can't get a response from my ping to the IP address I gave it. My IP address for FA4 is 10.1.1.1 255.255.255.252. My VLAN 10 ip is 10.203.10.2 255.255.255.0. I can't get an IP route to this FA4 ip address. Can anyone help me figure out how to get this port active?
Thank you for any help you can give.
Solved! Go to Solution.
06-07-2013 09:35 AM
Kindly post 'show run' and hide sensitive info. Are you pinging from inside LAN and from which device?
06-11-2013 08:14 PM
I'm not sure exactly what you are trying. Are you trying this directly from the router? If so what is the source of your ping. Also if you are trying from a PC make sure it has an IP in the subnet of VLAN 10 and the default gateway is your VLAN 10 IP.
I am also a little confused why you have the statement "IP default-gateway" as the IP address of your router. Usually this is the address of the next hop router. Also on a router or layer 3 device it is typically set with the "IP route" command instead.
06-12-2013 04:53 AM
Hi Shannon,
configuration of your router is little bit chaotic for me.
1) your default gateway on router is same as your FA4 interface which doe not make sense
2) your VLAN10 interface on router has IP 10.1.1.9/29 and you told that VLAN 10 on switch has 10.203.10.2
If you want to make VLAN routing with this router so you will have to configure vlan subinterfaces on router and trunk on switch on port which hs uplink to router.
Best Regards,
Jan
06-12-2013 06:30 PM
hi shannon,
i noticed your LAN subnet was changed compared to your orig post. could you make a brief description or provide a network diagram of your setup?
kindly note that FE4 is your WAN port and FE0--3 are your layer 2 only LAN ports.
as for the question for your LAN default gateway, you should set your clients to:
host IP: 10.1.1.10 - 10.1.1.14
subnet mask: 255.255.255.248
default gateway: 10.1.1.9
06-16-2013 03:31 AM
Hello
The port you have the ip addrees on is a routed port with an ip range different to to the vlan
Ip routing enabled
What exactly are ypu trying to acheive?
Is the pc directly connected ? If so which port?
Also a router generally equires an ip route not default gateway
Res
Paul
Sent from Cisco Technical Support Android App
06-07-2013 09:35 AM
06-11-2013 12:01 PM
Here is my Show Run. I am trying to ping my fa4 interface from this router, but I can't get it to work. If my VLAN IP and fa4 IP is on different subnets, then what would be my default gateway for that?
hostname Router_1
boot-start-marker
boot-end-marker
enable secret 5 $1$ev6X$HjtwiFNNxEcL0vkOUxdrA.
no aaa new-model
dot11 syslog
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
archive
log config
hidekeys
interface Loopback10
ip address 10.203.10.1 255.255.255.0
interface Loopback30
ip address 10.203.30.1 255.255.255.0
interface Loopback50
ip address 10.203.50.1 255.255.255.0
interface Loopback70
ip address 10.203.70.1 255.255.255.0
interface Loopback90
ip address 10.203.90.1 255.255.255.0
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 10.1.1.1 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip address 10.1.1.9 255.255.255.248
ip default-gateway 10.1.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
privilege level 15
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 7 110A1016141D
logging synchronous
login
scheduler max-task-time 5000
end
Router_1#
Thanks again for the help!
06-11-2013 08:14 PM
06-12-2013 04:07 AM
This is from my personal lab and I am trying to set this up for my CCNA Wireless studies, but I was unable to get to my WLC. I am used to using 3750s, 3560s, and 4507s so this is a totally new type of switch to me. I thought the FA4 port would be the default gateway since it is the L3 port, but I can't ping it from either the PC with a vlan10 IP or from the switch. I am a little bit baffled by how the 4 switchports and 1 L3 port work together on the same switch since they can't be in the same subnet.
06-12-2013 04:53 AM
Hi Shannon,
Best Regards,
Jan
06-12-2013 06:30 PM
hi shannon,
06-16-2013 03:31 AM
Hello
Ip routing enabled
Res
Paul
06-20-2013 04:28 AM
Thank you all for your help. I was finally able to piece this together and figure out what I was doing wrong. It is now connected to my other switch successfully!!!
Thank you all!
