891W ISR: Does SSH corrupt passwords?
ValleyITPC
Does SSH have some kind of issue with using passwords with special characters or something?  I am working with an 891W.  I have ony done the basic config on it using CCP Express so not much is done yet, but I do have enable and enable secret both set the same.  An example password I haev is passwprd!PASS! with the only special characters being the ! .  I can log into the router via CCP Express in a web browser, but when I ssh to the router and enter my creds it tells me Access Denied.
It is most likely that I have done nothing of consequence to cause this since if memory serves the only thing I did between when SSH worked and now when it doesn't, is edi vty 5 15 and vty 0 4 with "transport input ssh", (thus removing telnet).  I certainly have not chnaged the password so the one that gets me into CP Express shoudl work on SSH too.  It is the only username I have ever specificed.
Can anybody help?
cadet alain
to connect with ssh to a router you need a user/password defined in the router with the username xxx password yyy command and you must have login local configured under the vty line.
Can you do show run | be line vty as well as show run | i user either directly into CLI or with the command window in CCP.
Regards.
Alain
cadet alain
Regards.
Alain
I have much to learn.  Much.  I think I only added vty 0 4 because the Software Config Guide for the 890's sort of implied Ishould, but I later saw that vty 5 15 was already there by default.  So I compared the two and noticed that "login local" thing.  My vty 0 4 had only "login".  The SCG did not mention this little fact (perhaps the documentation team needs to know?) I guess "local" means a password list local to the rotuer as opposed to some kind of external one or someting.  Adding that fixed the problem though.
I've always known that I need to become CCNA to even unbox a Cisco router but this kind of stuff just proves it.  That will take time of course but meanwhile I will need to use this forum frequently I think.  Thank you Alain for your help!
you're welcome.
Yes login local means use the user/password credentials configured locally on the router, if you want to use credentials stored on a radius/tacacs+ server you would need to configure AAA and either use a default method and then it will automaically applied to all lines or a named method which you can explicitly configure on a line to override the default method.
here is an example:
1) default method which uses radius server and defaults back to local if the server is not responding
  aaa new-model
  aaa authentication login default group radius local
  radius-server host x.x.x.x key XXX
  so nothing to configure under lines
2) named method MY_AUTH using radius and line password if the server is not responding
aaa new-model
aaa authentication login MY_AUTHt group radius line
line vty 0 4
password cisco
login authentication MY_AUTH
Regards.
Alain.
I apologize for not replying sooner, sometimes I lose track. Will remember to review this thread soon. Thank you!
