ā06-15-2020 05:06 AM
While doing ATP for a new network, I have noticed that when the master fails in a 2 switches stack (9200 switches)
I am having 4.2 seconds packet loss.
I am wondering if this duration is acceptable (I think it is too long) and if there is some documentation that can give me the expected result for that kind of failure.
Alon.
ā06-15-2020 07:29 AM
Are the switches layer-2 or layer-3? Usually, we layer-3, the fail-over takes a little longer. Have a look at modifying
stack-mac persistent timer parameters and test again.
ā07-22-2020 05:25 AM
Thank you for your reply.
The switch is Layer 2 only.
