9200L 9200 OID for PoE device power draw
mandm
I use 9200 switches in my environment and am interested in obtaining the power draw of certain PoE devices on specific interfaces.  What is the OID to use for that?
6 Replies 6
marce1000
  - Have a look at  https://github.com/librenms/librenms-mibs/blob/master/CISCO-POWER-ETHERNET-EXT-MIB
     The closest I could find for the time being:
     >peExtPsePortMaxPwrDrawn OBJECT-TYPE
               SYNTAX Unsigned32
               UNITS "milliwatts"
               MAX-ACCESS read-only
              STATUS current
              DESCRIPTION
              "This indicates the maximum amount of power drawn by the PD
              connected to this interface, since it was powered on."
              ::= { cpeExtPsePortEntry 10 }
  M.
Is there an OID?
@mandm   Ref : https://cric.grenoble.cnrs.fr/Administrateurs/Outils/MIBS/?oid=1.3.6.1.4.1.9.9.402.1.2.1.10
                    Actually there was  a syntax error in my original post that should have been
                 :                                 cpeExtPsePortMaxPwrDrawn
mandm
I tried the oid but it gave the message [noSuchName]?
  - Sometimes the OID gets a slightly different name; you may get insights from this example :
    % snmpbulkwalk -v2c -c <community> -OQUs -m CISCO-POWER-ETHERNET-EXT-MIB -M <path-to-mib> udp:<switch-name>:161 cpeExtPsePortEntry
  M.
mandm
Thank you.  What if I wanted to narrow it down to a specific switchport?
